Big block wp question
Old Jun 28, 2017 | 11:20 PM
TOM B1's Avatar
TOM B1
Default Big block wp question
On a long water pump with the 2 coolant ports on the top of the water pump, is there a inlet and outlet on these 2 ports or doesn't it matter.
Old Jun 28, 2017 | 11:29 PM
TimAT's Avatar
TimAT
The one toward the center is for the bypass hose to the intake. The heater hose connection should be just above the radiator hose connection on the right side.
Old Jun 29, 2017 | 07:15 AM
Tiger Joe's Avatar
Tiger Joe
^x2.
in the pic on the right, the top port is typically the bypass, the port with sort of has "A" pointed at it is heater hose
Old Jun 29, 2017 | 12:10 PM
TimAT's Avatar
TimAT
Looking at that picture, and not sure what year your BBC Corvette is, that pump is way different than the one on my 69 BBC. I don't have that boss on the left side. It would not fit my car with power steering.
Old Jun 29, 2017 | 01:36 PM
71 Green 454's Avatar
71 Green 454
Also, it shows B as 5/8". Is that right for your car? My '71 454 requires 3/4" shaft.
Old Jun 29, 2017 | 01:42 PM
Rebelrob's Avatar
Rebelrob
Yeah, mind does not look like that. I have the bypass only, from intake to top of WP.
But I have the short water pump-model ie. (Corvette), like most for a BB.
Old Jun 29, 2017 | 01:46 PM
USAFVeteran's Avatar
USAFVeteran
Well, I'm lost now. My big block couldn't fit a long water pump. If I had a fan connected to it, it would hit the radiator.
Hmmm....
Old Jun 29, 2017 | 02:07 PM
John 65's Avatar
John 65
Here's a shot of mine so you can see the hose connections.
Has electric fans and non corvette specific brackets and pulleys.
Old Jun 29, 2017 | 03:29 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
ALL Corvettes use the short pump.
Old Jul 1, 2017 | 12:17 PM
TOM B1's Avatar
TOM B1
GOOD CATCH
forgot to say that this engine is far from stock.
So the one on the drivers side is for a bypass if used and the one on the pass side is for the heater if used.
please look at My Profile for pics
To Big block wp question
