Hooker Sidepipes
Old Jul 1, 2017 | 07:28 PM
benito's Avatar
benito
Default Hooker Sidepipes
After waiting 4 months for the side pipes (the headers came right away) I'm having a little trouble slipping the side pipes onto the collectors. I do not want to mess up the chrome, so I've been gentile with it.
Is there some special way to slip the pipes on. Its a very close fit.
Old Jul 1, 2017 | 07:34 PM
TimAT's Avatar
TimAT
Get a big can of anti-seize!! Liberally coat the ID of the sidepipe. They should be tight so you don't have a big leak. The anti-seize will give you a little lube. With the added benefit of being able to remove the pipes later without a fight. There is also a pinch bolt- remove that and drive a small wedge in to spread to end of the pipe a little bit.
Old Jul 2, 2017 | 07:52 AM
3JsVette's Avatar
3JsVette
Great advise. Just add patience.
Old Jul 2, 2017 | 09:51 AM
benito's Avatar
benito
Sounds perfect. Wish I would have thought of that (WD-40 did not work)
Old Jul 2, 2017 | 11:37 AM
REELAV8R's Avatar
REELAV8R
Exactly!
Old Jul 11, 2017 | 11:35 PM
macrohard's Avatar
macrohard
...and a rubber mallet.
"Just tap it in. Just tap it in. Give it a little tappy. Tap Tap Taparoo.”
To Hooker Sidepipes
