Headlight question about springs
Old Jul 10, 2017 | 03:26 PM
cromwell74's Avatar
cromwell74
Default Headlight question about springs
Hi!
My headlights has worked fine until yesterday...
This problem started when I noticed that one of the springs on the right headlight was hanging loose, so I put it back in place where it should be -and now that light won´t go down anymore...
(The spring I removed was on the outer left side of the light)
I guess I have to remove that spring again to fix this problem??
Anyone else had this problem with the springs?
Old Jul 10, 2017 | 03:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Did you possibly knock off the vacuum relay hose while reinstalling the spring?
Old Jul 10, 2017 | 06:20 PM
Peterbuilt's Avatar
Peterbuilt
You may have a leak in the actuator or relay, here's how to test parts.
http://www.corvette-101.com/vacuum.htm
Old Jul 11, 2017 | 11:16 AM
Alan 71's Avatar
Alan 71
Hi c,
The headlight door mechanism and spring connections should look something like this.
Perhaps the linkage needs to be adjusted a little bit so the actuator can pull the door closed from the locked 'up' position?
Regards,
Alan
Old Jul 11, 2017 | 12:17 PM
7T1vette's Avatar
7T1vette
Are you speaking of the little springs on the headlamp bulb buckets; or are you referring to one of the springs on the main mechanism?
If the latter, I suspect you have had a part failure in the mechanism and the spring just fell loose because of that failure. Check it out well....there is likely a broken piece in there somewhere.
Old Jul 11, 2017 | 03:27 PM
Alan 71's Avatar
Alan 71
Hi c,
Good Question!
This little spring?
Regards,
Alan
Old Jul 12, 2017 | 06:57 AM
cromwell74's Avatar
cromwell74
Originally Posted by Alan 71
Hi c,
Regards,
Alan
Hi Alan!
I now disconnected the first spring from the left side (as it was in the first place when the lights worked) and now the lights work again!
I guess the vacuum system must be a bit tired when it won´t work with all four springs connected?
The right sided light comes up a bit later than the left one and is much slower when rising.
Would there be any idea for some wd-40 lubricant somewhere??
To Headlight question about springs
