Other than needing a different intake and valve covers is their anything that I will encounter when installing 12558062 vortec heads on an early 350 block? Just wanting to make sure before I get very far into this project. Thanks Larry
Is that because the threaded hole in the head is too small?
Yes. I bought and installed a thermostat housing that has a threaded port for the temp sender. It takes a little bit longer to register on the gauge but it is accurate once the thermostat opens.
There is a passage that comes up from the water pump to the head deck on the front passenger side of the block. Older heads have a hole that matches and goes to the water passage but the Vortec heads don't have the hole. I'd put the hole through the head into the water passage. It might not be necessary but it won't hurt to put it there.
check you accessory brackets and throttle brackets to see if any connect to the intake manifold, you may have to bend them or replace them to work with vortec intake.
I just installed some Vortec heads on a late 70s block. By the time I modified them for a high lift cam, etc. etc., I think it would have been better in the long run to get some $800 Blueprint aluminum heads.
Also I didn't use any type of coolant bypass and I haven't had any problem in thousands of miles.
I know it conflicts with the alt. bracket, ac support rod on serp brackets and throttle cable mounts on my k10. My vette didnt have ac on it when I bought it so no idea what that bracket and factory throttle mounts look like.
