hey. Got an open reading in my headlight connector power. I can see the kink but cant get to it because its buried in the connector housing.
I plan to depin it but not really sure how those pins are in there. It VISUALLY looks like you can take a screwdriver to the connection end, pry it down and push the whole thing out. Also need to know what the pin style is called so i can go buy some new pins. Any knowledge from the old timers would be hot.
GM used Packard connectors. Specifically, Packard Type 56. Google them and you can see how they lock into the plastic connector bodies. The male side unlocks with a small squeeze. The female side takes a pick.
Thanks a bunch! Much appreciated. Now to order the terminals and get back on the road without worrying about working the wires around to get it working!
The terminals and some of the connectors are easy to find. It's possible to crimp them reasonably with pliers but if you do so I suggest soldering as well. The heavy crimp tools that make factory-like crimps are expen$$$ive. Sargent makes hobbyist duty crimpers for far less $$--when using them you must start at the larger die sizes and work your way down to get secure crimps.
The sealed beam male prongs are 5/16", and to do it correctly require both series 56 & 59 connector. These are actually two different connectors. The correct number for the single wire is Auveco #18651 and the double wire is #18690. These connectors are tin plated brass as the original connectors were just brass. And yes, the good crimpers are expensive.
