Vacuum system gurus
Old Jul 4, 2017 | 10:09 AM
Duntov's Avatar
Duntov
Default Vacuum system gurus
Currently my wiper door opens with the wiper switch, however when the headlights are on it opens as well. Any suggestions on this one?
Old Jul 4, 2017 | 10:17 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
My guess is that you have the small vac line for the relay cans at all three tied together....to simplify it...the wiper relay can and headlight relay cans are tied together at the small actuator hose. These require vacuum for the doors to stay shut....dropping vacuum at the can allows the plunger to induce vacuum.....
This should be easy to find if you are patient......there are three going into the firewall.....one supply and one for the wiper door relay and one for the pair of headlight relays.......you are crossed up under the dash or at the headlight switch......
Jebby
Old Jul 4, 2017 | 10:49 AM
Alan 71's Avatar
Alan 71
Hi D,
No guru here!!!
Check the small (control side) hose routing as J suggests.
Remember to check the hose connections on the 4 parts of the system that are behind the dash.
Noting the color of the hose stripe makes it a bit easier to verify the correct routing.
Regards,
Alan
Old Jul 4, 2017 | 08:35 PM
MYblu69's Avatar
MYblu69
Jeepers, you are good Alan! If you need correct hoses etc, see "The Vette Doctor in CT. Has great product.
To Vacuum system gurus
