L82 Harmonic Balancer Replacement
Old Jul 6, 2017 | 03:19 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Default L82 Harmonic Balancer Replacement
When I start my own personal project from hell this winter, I'm going to replace my almost 40 year old harmonic balancer, so I have an associated dumb question: is the L82 crank internally balanced from the factory or do I need to buy an external balance harmonic balancer?
Adam
Old Jul 6, 2017 | 03:23 PM
TimAT's Avatar
TimAT
Internal. Chevrolet V-8 except for the 400SBC and 454BBC were internal balance. Not 100% sure about the 348/409's.
Old Jul 6, 2017 | 04:59 PM
NewbVetteGuy
Thanks, Tim.
8" is the standard size for 350's, right?
Can anyone recommend a couple good value-focused brands?
Adam
Old Jul 6, 2017 | 05:09 PM
jim2527's Avatar
jim2527
Originally Posted by NewbVetteGuy
Thanks, Tim.
Adam
Could be a 6-3/4"
This ones popular: http://professional-products.com/har...nic-damper-int
Old Jul 7, 2017 | 10:26 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
8" is the high performance size = 350 hp .
the smaller unit was for lower hp ouput engines.
Old Jul 7, 2017 | 10:49 AM
7t9l82's Avatar
7t9l82
The L-82 used the 8" balancer the engine is internally balanced
Old Jul 7, 2017 | 08:21 PM
TimAT's Avatar
TimAT
I've swapped a 6-3/4 balancer for an 8" one countless times. Just need to get the correct timing pointer for the balancer. THE 8" has a little more mass/inertia.
Old Jul 7, 2017 | 09:42 PM
7t9l82's Avatar
7t9l82
Its.always better to use the correct balancer. The extra mass controls the harmonics better at higher rpm.
Old Jul 8, 2017 | 06:22 PM
TimAT's Avatar
TimAT
Exactly why I opted for the bigger heavier balancer!
Old Jul 8, 2017 | 07:29 PM
sparky77's Avatar
sparky77
I got mine for my L82 77 at Summit it's an 8 inch and is there brand.It fit good and the timming marks are right on the money.
Old Sep 7, 2017 | 02:09 PM
NewbVetteGuy
Update: Well, I went overboard, but I got the SFI ATI Super Damper from a guy on ThirdGen for $160, so I couldn't say no... Way better than I needed but, I'll take it.
http://www.jegs.com/i/ATI/085/917200/10002/-1
Adam
Old Sep 7, 2017 | 02:26 PM
MelWff's Avatar
MelWff
you do know the damper is smaller than what you have now and may cause you problems trying to line up your timing mark with the pointer on the timing cover?
Old Sep 8, 2017 | 12:05 AM
NewbVetteGuy
I think I'm too dumb to fully understand the implications...
The dampener is only a VERY little much smaller than the one I have.
I didn't even know that these cars cam with a timing marker (never noticed mine) I have no understanding of how to setup timing so it's never occurred to me.
I will be doing a head, cam, lifter, push rod, timing chain, timing cover, and harmonic balancer replacement starting this winter. My thought is that while I'm doing all of that, I can just move the timing pointer to where it's supposed to go, right?
People replace harmonic balancers all the time, it can't be that hard, right? -Am I missing something obvious?
Adam
Old Sep 8, 2017 | 11:21 AM
MelWff's Avatar
MelWff
perhaps the word pointer was incorrect, I meant the timing tab, with the numbers. Typically it is a fraction of an inch away from the balancer and when setting the mark/iine on the balancer to the number on the tab your viewing orientation/angle to the tab has no consequence. Unless you have a way of moving whatever timing tab you intend to install on the engine close to the balancer your viewing orientation/angle will effect the accuracy of your timing initial or total adjustment.
Old Sep 8, 2017 | 01:13 PM
NewbVetteGuy
Thanks for that, I think I get it now.
What is the fix?
Do I just buy a timing pointer tab that's made to work with my new balancer and install it per the instructions and I'm good?
Adam
Old Sep 8, 2017 | 01:31 PM
NewbVetteGuy
I have another dumb question that I probably should've figured out before I bought the thing: I noticed that ATI sells a version of the Super Damper that they say is for Serpentine belts; does that mean that you can only run a serpentine pulley setup with a serpentine-specific damper or why would they even sell such a thing?
Adam
Old Sep 8, 2017 | 01:32 PM
MelWff's Avatar
MelWff
I found a number of 7" balancer timing tabs
https://www.summitracing.com/search?...1%2B4294943550
The link you provided further up in this thread was for a stock multi-belt drive like your l-82. That is what you bought, correct? You did not buy a balancer for a serpentine drive, correct?
Old Sep 8, 2017 | 01:33 PM
NewbVetteGuy
I was just about to ask Summit. ;-)
So this really is just as simple as buying a new timing tab that matches the damper's diameter?
Adam
Old Sep 8, 2017 | 01:42 PM
MelWff's Avatar
MelWff
yes, the tab you buy has to match the balancer diameter
To L82 Harmonic Balancer Replacement
