Passenger door will not open
Old Jul 10, 2017 | 11:41 AM
dyerk's Avatar
dyerk
Default Passenger door will not open
Unable to open the passenger door. The lock can be turned with a key from outside but a little sticky from inside. The door was always harder to close fully and required a harder slam than the drivers door. How do I get it open?
Old Jul 10, 2017 | 12:45 PM
lsintampa's Avatar
lsintampa
check this out:
https://www.corvetteforum.com/forums...ring-door.html
Old Jul 15, 2024 | 12:10 PM
DVET3's Avatar
DVET3
3rd Gear
Default 05 Corvette Drivers Door Touch Pad not working.
So here’s the issue, hope I can find some help here.
Issue: 2005 Corvette (Base) Driver Side Touch Pad doesn’t work at all. I get in and out of the vehicle using valet mode to put down the windows and open it from the interior door switch. When pressing the button I don’t even hear the clicks.
I swapped out the touch pads being they are universal everything works on the passenger side.
I even put the drivers side pad from my buddies 07 Vet and that didn’t work.
I checked all the fuses and relays both under the hood and under the carpet. I opened the door to see if I seen any loose, spliced/sliced wires and nothing.
The actuator works being it opens from the interior button.
No codes on the OB2 reader.
Any help would be amazing and thanks in advance.
Old Jul 15, 2024 | 01:54 PM
vettebuyer6369's Avatar
vettebuyer6369
Not sure why you would ask this question on a thread that’s been dead for 7 years in the C3 section.
To Passenger door will not open
