no spark
Old Jul 11, 2017 | 11:17 AM
Tony1947's Avatar
Tony1947
Cruising
Default no spark
I'm trying to start 70 350 300hp I have spark coming out of coil but no spark at plugs. Need help
Old Jul 11, 2017 | 11:54 AM
MelWff's Avatar
MelWff
Remove the distributor cap and check the inside of the cap and the rotor.
Old Jul 11, 2017 | 12:04 PM
7T1vette's Avatar
7T1vette
If a points type system:
bad condenser; points pitted/bad/ set wrong; distributor cap defective/not machined properly; main distributor wire from coil bad or not installed completely; rotor defective or contact tab not making good contact; distributor not grounded (either by ground wire inside to the housing or by the distributor lockdown piece not being able to pass electrical ground from dist housing to engine block)
Old Jul 11, 2017 | 12:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My hunch tells me the points are closed. Have you checked the gap?
Old Jul 11, 2017 | 01:04 PM
Tony1947's Avatar
Tony1947
Cruising
Thanks to everyone! Does anyone have a picture of starter wiring for same cars.
Old Jul 11, 2017 | 02:10 PM
MelWff's Avatar
MelWff
how did you jump from a coil producing spark but nothing at plugs to now asking about starter wiring?
Old Jul 11, 2017 | 02:24 PM
Tony1947's Avatar
Tony1947
Cruising
Just wanted to make sure I had the right wire going from starter to coil.
Old Jul 11, 2017 | 02:27 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
if you have spark at coil, ignition (points or electronic) are working.
after that it is rotor/ cap and then wires.
Old Jul 11, 2017 | 03:16 PM
MelWff's Avatar
MelWff
Default Wires
If you have the original wire harness from a 1970 point system you have two wires in one clip attached to the + coil post. Why would the wires have suddenly changed are you leaving some part of this problem out of your post?
Old Jul 12, 2017 | 06:50 PM
TimAT's Avatar
TimAT
Spark at the coil and not at the plugs really narrows the playing field. Problem is either the rotor or the cap, or both. No question about that. IF it was anything else, there would NOT be spark at the coil.
To no spark
