Need help with parasitic drain
Old Jul 14, 2017 | 11:26 AM
tmart05z's Avatar
tmart05z
Cruising
Default Need help with parasitic drain
Need some help on this. My battery dies overnight. Battery is new. Must be parasitic draw right? I charge the battery and the multimeter reads 12.91 volts. I disconnected the negative battery cable and switched the lead over to 10a to see how much amps is "leaking" for a very brief time (less than a second) it reads 4 amps and quickly goes down to 0. The clock in the car began ticking when I did the test. I would imagine the connection was good. I then switched back to test the battery voltage. It read 12.91V again. I dont think its the multimeter. Any advice helps!
Old Jul 14, 2017 | 12:29 PM
MelWff's Avatar
MelWff
pull the clock fuse and place your meter on milli amps, mA, not amps and redo the test.
Old Jul 14, 2017 | 03:02 PM
tmart05z's Avatar
tmart05z
Cruising
I got a new multimeter and its reading 0.56 on the car 10a setting. So thats 560 milliamps. Isnt the most supposed to be 50 milliamps?
Old Jul 14, 2017 | 07:02 PM
MelWff's Avatar
MelWff
start pulling fuses one at at a time until you find the circuit causing the draw.
any electrical modifications to the car?
Old Jul 14, 2017 | 08:47 PM
tmart05z's Avatar
tmart05z
Cruising
Looks like BUBBA beat me to the timer switch behind the glove box. The amp was 0.78. I pulled the fuse it went to 0.01. Put the fuse back in and it went back up to 0.78. I think I found the problem!
To Need help with parasitic drain
