I had an issue with a 421 SBC once-- the mechanical advance springs were right on the edge of letting the weights move. Timing was all over the map. Swapped to a little more spring and it settled right down. Still had a good curve too. Might be worth a shot in your case too.
One other thing, I don't know if the subscribers or the newsstands get their issues first. I subscribe, and got the issue, the September issue, a few days ago.
did you disconnect the vacuum advance and plug the line and drive it to see if the problem went away?
not sure how you transcribed those numbers but I found for the VC-1810
0 degrees of advance at 4" of vacuum
16 degrees of advance at 8" of vacuum
The VC1810 starts working at 3 to 5"hg and produces a max of 16 degrees advance (that's 8 distributor degrees) at 5.75 to 8"hg.
I believe you should have a can that produces max advance a minimum of 2"hg below your idle vacuum for proper operation and decide how much advance you need.
Dan - My iron headed, high compression 60's motors (the L36 and '65 4-4-2) will buck like crazy at low-load with any more than 10* vacuum lead. Less is better. Of course our CA wannabe 92 "Premium" doesn't help things.
That's interesting Jeff. I wonder if it is the gas? On my stock iron head L36 I run 17 initial, 17 mechanical and 15 vacuum with a Comp 270HR hydraulic roller. I can slow right down to the 800 rpm engine idle speed in 4th gear and when you step on it, it just pulls away with no bucking, kicking or hesitating. That's on 91 octane with no ethanol. Our best gas here available pretty well everywhere is Chevron 94 octane, again with no ethanol. Everything under 91 octane here has corn added.
