'82 electrical issue?
Old Jul 15, 2017 | 11:12 AM
ESU's Avatar
ESU
Default '82 electrical issue?
Gents, have an 82, 63k original miles mostly non bubba'd. Last week went out to a local car gathering and it ran great, no issues. 3 weeks ago I re-installed the original Delco radio after having it re-furbed. Also installed original style 8-10 ohm speakers to go with it. Anyway, went to take it out of the garage today cause it needed an inspection. Put the key in and turned it and zippo. No cranking no nothing not even a click. Thought maybe dead battery even though I keep a tender on it so I broke out the charger and its not really taking a charge. Thought the meter would be pegged but its not. I have no interior dome lamp, no radio, no key buzzer, no horn, no fan. The light under the hood works, very bright, and the exterior lights work. I checked as many fuses as I can reach, basically only the top 2 I cant and they are good. SInce the only thing Ive done in the last 2 years has been the radio I'm leaning towards some issue with that, some kind of drain? But it has been in 3 weeks as I said. I'm totally confused, any thoughts?
Old Jul 15, 2017 | 11:59 AM
ESU's Avatar
ESU
correction, no exterior marker lights, just headlights. Also found a 30 amp fuse coming off the battery terminal going to the ECm maybe and that was good.....
Old Jul 15, 2017 | 12:02 PM
hugie82's Avatar
hugie82
If you have bright lights, your battery isn't dead. It sounds like the power wire coming off the starter has broken contact. You have your positive cable coming from the battery and then you'll have a heavy gauge wire coming from the same post. That's the one you want to check.
Old Jul 15, 2017 | 09:10 PM
TimAT's Avatar
TimAT
Starter Extension-- Right side of the distributor on the firewall. 6 way connector. All the power for the car and the starter run thru it.
Old Jul 16, 2017 | 10:00 AM
ESU's Avatar
ESU
Looked at a picture of this item, looks like fusible links? also I looked and I'll be dammed if I see it. By right side you mean passenger side? Might be under a plastic housing if that's the case.
Old Jul 16, 2017 | 06:39 PM
ESU's Avatar
ESU
Located it, jiggled it a little and everything started buzzing and beeping, car started right up. Guess I'll start with ordering the part and go from there. thx again,,,
To '82 electrical issue?
