Tripower center carb float adjustment question
Old Jul 17, 2017 | 06:48 PM
Jims427400's Avatar
Jims427400
Default Tripower center carb float adjustment question
Center carb float was not showing any fuel rocking car through the inspection hole. I think I'm supposed to have a level of + or - 1/32 correct? My book says to turn screw counter clockwise 1/6 turn per 1/32 of level. But after several attempts I've lost my original setting and I need some help with how to set the float level from scratch. Plus I've destroyed the 2 leather gaskets on the nut and screw..
Thanks all,
Jim
Old Jul 17, 2017 | 07:40 PM
PAmotorman's Avatar
PAmotorman
Thanks all,
Jim
the screw is the lock the nut is the adjustment. if you screw the needle seat down too far the nut will not fit over the needle seat with the gasket on there. remove the gasket put the adjustment nut on and turn it counter clockwise to get it back up.
Old Jul 17, 2017 | 08:16 PM
Jims427400's Avatar
Jims427400
What if I can't get the nut on any more? It's flush with the top of the carb..I got it backwards and was turning the lock screw to adjust carb.
Old Jul 17, 2017 | 08:23 PM
TimAT's Avatar
TimAT
Take a small needle nose pliers and gently grab the top of the needle and seat and back it out (UP) until you can get the nut on and back it out some. Typically the top of the brass is about the same level as the thickness of the nut.
Old Jul 17, 2017 | 08:28 PM
PAmotorman's Avatar
PAmotorman
just using the nut without a gasket should allow you to turn it back out. if not find a small screwdriver that will wedge into the threaded hole and turn it out using the screwdriver
Old Jul 18, 2017 | 10:17 AM
Jims427400's Avatar
Jims427400
Update:
I tried grabbing needle with pliers and can't get brass to come up enough to get threads to catch. And worried I'll damage threads if I get too aggressive. Any other ideas to get needle up enough to catch it? Does the needle thread up or just raise up with the adjustment nut?
Old Jul 18, 2017 | 11:00 AM
TimAT's Avatar
TimAT
The nut raises and lowers the complete assembly. The threads on the OD of the needle and seat is where the adjustment comes from. The internal threads are for the locking screw. There are a couple of O-rings on the assembly, to help seal it. You should be able to get just a needle and seat with the O-rings from your local parts store- a Holley needle and seat, there are not many options- couple of different sizes and one for alcohol and one for gas. If all else fails, stick an easy out in it and wind it out, then replace the whole thing. Be easier than pulling all 3 carbs to just replace that one thing.
Old Jul 18, 2017 | 11:03 AM
Tiger Joe's Avatar
Tiger Joe
FWIW you can pull just the center carb. takes a bit of wiggling and you have to tilt your head just right, but Ive done it a couple times already on my tri power.
Old Jul 18, 2017 | 11:19 AM
MelWff's Avatar
MelWff
as you now found out you were turning the assembly the wrong way. To raise the float level you turn the nut counter-clockwise.
Old Jul 18, 2017 | 11:37 AM
VancouverL71's Avatar
VancouverL71
Hi Jim,
Just so we understand, the lock nut, the screw and the two gaskets are all removed right now and the needle valve has been accidentally screwed in too deep to get pliers on the edge to unscrew it back out of the bowl?
If this is correct, you will likely have to remove the float bowl which as you know takes some time on the tri power as I have always removed my front carb to access the middle bowl. (not sure if this is required but this is what I have always done as room is pretty tight)
If you can back the needle valve back out enough by grabbing it with needle nose pliers, mine has about 3-4 threads exposed before putting the nut and lock screw on. This should get you in the ball park so you can set it properly when running.
I just went through this recently and I can tell you one thing for certain. Make absolutely sure that your gas tank and gas are cleaned. As you know, the tripower has no inline filter, just the tank filter sock and the bass filters at the carbs. Mine was repeatedly flooding as old rust and grit make it from my 50 year old fuel tank, somehow through the sock in the gas tank and into carb needle valve causing it to stick in the down position and flood my engine. I finally solved that problem by removing gas tank and removing all rust and deposits.
Good luck. Pete
Old Jul 18, 2017 | 12:28 PM
PAmotorman's Avatar
PAmotorman
Update:
wedge a small screwdriver in the hole like I posted above. even taking the carb off is not going to help you.
Old Jul 18, 2017 | 01:13 PM
Jims427400's Avatar
Jims427400
I used a small set of hemostats that I had and was able to get that down into the flats. Turned it enough to get it threaded up to get nut on it. Used a set of hollow punches to make a new gasket cause I messed up the first one. And then realized I left key turned on all night so my NEW battery is dead..
Do I need a gasket under the nut and a gasket between top of nut and lock screw?
Thanks all..
And yes I turned the nut in the wrong direction. Got that figured out now.
Old Jul 18, 2017 | 02:24 PM
suprspooky's Avatar
suprspooky
yes you need both, tri-powers are cool when they're working and not leaking
I would recommend buying the correct gaskets, it'll save headaches in the long run.
Have fun and keep a fire extinguisher handy (not joking) I haven't had to use mine but I keep it close by when working on the carbs (20# CO2 so I don't get crap in the engine)
Old Jul 18, 2017 | 03:00 PM
Jims427400's Avatar
Jims427400
I agree on the correct gaskets. Autozone ordered them for me $12.00/10. Here tomorrow.
Guess a fire extinguisher would be a good idea. I have one but not sure it's Co2.
Old Jul 18, 2017 | 08:29 PM
TimAT's Avatar
TimAT
C02 works. ABC works too, but messy. That d(**& powder gets into everything. I'm a fan of Halon/Halotron.
To Tripower center carb float adjustment question
