Ignition wiring / Kill switch problem
Old Jul 20, 2017 | 11:22 AM
Hayes69's Avatar
Hayes69
Default Ignition wiring / Kill switch problem
While I have the dash apart, I decided to put in a kill switch. I pulled the white connector harness off the top of the steering column. I spliced a switch into the purple wire and reinserted the connector. I heard it click. But now I get nothing when the switch is closed.
Would the lights and accessories that normally go on when the key is in the ON position be affected by this?
I've tried a crude jumper over the switch but it didn't work. Not sure how how many amps needs to be able to go through this wire to engage the starter.
Old Jul 20, 2017 | 11:38 AM
Hayes69's Avatar
Hayes69
Nevermind. I looked again and apparently there is a black connector right next to it that I had pulled off as well. I hooked that back in and everything is working well now.
I'm doing this blind because I couldn't get the dash all the way out. Can I just say that my least favorite part of the car to work on is the driver side dash?!
