Camshaft problems..
Old Jul 25, 2017 | 07:42 AM
jim2527's Avatar
jim2527
OK... #1 or #6
1. Place engine at #1 cylinder piston at TDC
2. Rotate engine
If #1 lifters and pushrods begin to rise as engine rotates your at TDC with #1
If #1 lifters and pushrods begin to fall as engine rotates your at TDC with #6
Old Jul 25, 2017 | 09:27 AM
stingraymaniac's Avatar
stingraymaniac
Originally Posted by leadfoot4
With all of the rocker arm nuts installed, but relatively loose, can you rotate the engine freely?
Yeah
Old Jul 25, 2017 | 10:02 AM
AirBusPilot's Avatar
AirBusPilot
Originally Posted by stingraymaniac
Don't understand why it's hitting, I have a couple of 492 angle plug heads on it
Sounds like your heads have been milled to the point of creating piston to valve clearance problems. Do you know the history of your heads? If they're 40 years old, who knows how many times they've seen a milling machine.
Old Jul 25, 2017 | 10:06 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The comp cam install manual says you shall install this way to have the cam at 0
Yes...that's CAM timing in relation to the crank/piston etc.
Leave all of that alone. But you need to rotate the engine one full turn to get #1 cylinder to TDC COMPRESSION stroke where both valves are closed. Then you can adjust that cylinder and move on through the sequence.
During adjustment you just need to barely take out the play. With #1 in position as described,,,turn adjuster while lifting up and down on pushrod. Just a light touch. When it just loses play you're at zero lash. Then turn it 1/2-3/4 of a turn more.
Make sure when you're at zero play that the cup in the lifter is not being depressed at all. It should be high and up against the clip. I'm guessing all the oil has been removed from lifters by now with the previous adjustments...so you'll have to pay close attention.
JIM
Old Jul 25, 2017 | 10:07 AM
427Hotrod's Avatar
427Hotrod
Any chance it's got wrong pushrods and rockers are bottoming or something??
JIM
Old Jul 25, 2017 | 10:15 AM
c3_dk's Avatar
c3_dk
JIM
Old Jul 25, 2017 | 10:20 AM
stingraymaniac
That's the way I have done it so I'm very confused right now
stingraymaniac
JIM
It's the standard length pushrods in it with 1.5 Lunati roller rockers
Old Jul 25, 2017 | 11:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
Are you rotating it with the plugs in?
Something isnt right there is no way the valves should be coming anywhere near the piston. Tons of room...
are you spinning the pushrods with your fingers or wiggling them up & down til theres no slack then adding your preload? easy to get fooled
Old Jul 25, 2017 | 11:40 AM
v2racing's Avatar
v2racing
Are you sure it's the exhaust valve hitting the piston. Did you replace the stock springs with Comp's recommended springs. Did you check free travel, valve keeper and top collar to seal?
Stock springs could coil bind with this cam and there may not be enough free travel. Either of these would cause it to bind up.
Mike
Old Jul 25, 2017 | 03:01 PM
Neil B's Avatar
Neil B
I agree. You'll hang the valves open and not build compression with improper valve adjustment, but I don't think you'll hit a piston. It's VERY easy to preload the lifter while setting valve lash on a hydraulic cam.
Old Jul 25, 2017 | 03:29 PM
Barry's70LT1's Avatar
Barry's70LT1
If 327 pistons were installed by mistake, would they poke their heads high enough to hit the valves ?
Old Jul 25, 2017 | 03:32 PM
  #33
stingraymaniac
It is a 327 i have bored to 331
Old Jul 25, 2017 | 04:05 PM
  #34
427Hotrod's Avatar
427Hotrod
Got any pics of valvetrain/pistons/heads?
JIM
Old Jul 25, 2017 | 05:06 PM
  #35
stingraymaniac
There it is at tdc
Old Jul 25, 2017 | 05:59 PM
  #36
427Hotrod's Avatar
427Hotrod
Good. one thing down.
It's got "universal" pistons that have same valve reliefs on all pockets. Meaning they can go in any cylinder vs many that have right bank and left bank. Also eliminates the common mixup on the middle cylinders of getting them in the wrong direction and not having the proper valve pocket line up with the correct valve.
Got any of the rockers at full lift, the pushrods etc?
JIM
Old Jul 25, 2017 | 06:04 PM
  #37
jim2527's Avatar
jim2527
When you look down the lifter holes with #1 at TDC what do you see? Cam lobes sticking up or the base of the lobes?
To Camshaft problems..
Old Jul 25, 2017 | 09:25 PM
  #38
OMF's Avatar
OMF
^^^^^this.....answer this question!!!
Old Jul 26, 2017 | 01:08 AM
  #39
c3_dk's Avatar
c3_dk
Old Jul 26, 2017 | 04:38 AM
  #40
stingraymaniac
That's an old picture it's assembled now, gonna see today if i can find any clues
