Camshaft problems..
Old Jul 24, 2017 | 03:36 PM
stingraymaniac's Avatar
stingraymaniac
Default Camshaft problems..
I'm in the process of rebuilding my 327 it's a standard 327 with flat pistons with 4 recesses for the valves, I bought a new camshaft for it : http://www.compcams.com/Company/CC/c...x?csid=80&sb=2
and have upgraded to Lunati roller rockers with 1.5 standard ratio
But now when I have pressure on the lifters and try to spin it it hits the pistons on the exhaust valve...
I have comp cams timing chain and if I advance the cam with 4 degree's could that solve the problem?
Old Jul 24, 2017 | 04:32 PM
MelWff's Avatar
MelWff
did you install the timing chain as explained in this video?
Old Jul 24, 2017 | 04:57 PM
OMF's Avatar
OMF
That's a pretty mild lift cam, shouldn't have problems with a .490" lift.
You may have over - adjusted the valve lash when trying to get zero lash, or you may have installed the cam and timing chain incorrectly.
Try backing the lash off until you can get a .002 feeler gauge between the valve stem and the rocker, and see if that change allows you to rotate the engine over. If you use checking springs on the valves, you can rotate the engine over in small increments and determine what piston to valve clearance you have. Should have around .050" as a minimum.
I don't think advancing the cam that small amount will solve your issue if it's assembled correctly and hitting the valve.
Old Jul 24, 2017 | 05:09 PM
stingraymaniac
This is how it's mounted
It's a hydraulic, shouldn't I adjust to zero lash and then go 45 to 90 degree's on that?
Old Jul 24, 2017 | 05:11 PM
stingraymaniac
Don't understand why it's hitting, I have a couple of 492 angle plug heads on it
Old Jul 24, 2017 | 05:12 PM
stingraymaniac
https://www.youtube.com/watch?v=DOdnWggBCUw
Yeah it's at zero now
Old Jul 24, 2017 | 05:14 PM
jim2527's Avatar
jim2527
Are you doing them all at the same time? There's a very specific order to adjust valves.
Old Jul 24, 2017 | 05:20 PM
stingraymaniac
I have adjusted accordingly to spec, but when I do that I can't rotate the engine..
Old Jul 24, 2017 | 05:25 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Could you explain to us how, EXACTLY, you adjusted the valves?
Old Jul 24, 2017 | 05:34 PM
jim2527's Avatar
jim2527
http://berlinetta.info/Lash.htm
Cliff notes:
Once you are sure that the engine is at #1 TDC the following valves/rockers can be adjusted:
exhaust - #1, #3, #4, #8
intake - #1, #2, #5, #7
First you must find "zero" lash. This step takes all slack out of the lifter-rod-rocker assembly. This is accomplished by grasping the rod and "jiggling" it so it clanks between the valve and the rocker arm. Tighten down the retaining nut ( by hand if possible) until the push rod can no longer "clank" between the valve and the rocker. THIS IS ZERO LASH! (I do NOT suggest "spinning" the push rod because the pushrod can/will continue to spin after 0 lash is reached !) As soon as 0 lash is reached, turn the rocker arm nut down 1/2 to 3/4's (max 1 full turn) of a turn in 1/4 turn increments. A 1/4 turn increment is recommended to set the lifter pre-load.
Rotate the crank 360 degrees and set the other half of the valves
exhaust - #2, #5, #6, #7
intake - #3, #4, #6, #8
Old Jul 24, 2017 | 05:36 PM
stingraymaniac
Like that but I went 45 degree's after zero lash
Old Jul 24, 2017 | 06:09 PM
leadfoot4's Avatar
leadfoot4
https://youtu.be/tS_893o64p0
For some reason, setting the lash on hydraulic lifters sees to trip people up. Videos like this, add to the confusion.
What "jim 2527" posted, is the easiest way to do it. Get cylinder #1 at top dead center, adjust 8 of the valves, rotate the engine one full revolution "clockwise" when facing the engine, and set the remaining valves, and you should be good to go.
Personally, I don't care for the "spin the pushrod until you feel some drag" method, for detecting "zero lash", because if you lubed both ends of the pushrod with assembly lube before installing it, the lube can easily cut the friction to the point where you won't feel any drag until you've already begun to compress the lifter.
With a new build, if you haven't installed the intake manifold, you can very easily watch the lifter, as you snug up the adjusting nut on the rocker arm. As soon as it looks like the plunger of the lifter moves, you're at "zero lash". At that point, turn the adjusting nut approximately 1/2 turn further, and you're set.
If you've done this, and your engine still won't rotate, possibly you dropped something in one of the ports, and didn't realize it.....
EDIT..............this is a "long shot", but I just thought of this. You didn't, by any chance, use one of those piston stop tools, that you install in the spark plug hole, when degreeing the camshaft, and forget to remove it, did you?
Old Jul 24, 2017 | 07:26 PM
OMF's Avatar
OMF
I've had timing chain kits that have the dimple at the top of the cam sprocket when at TDC....really confused me. With the gears the way they are in the pic, are the cam lobes on cylinder #1 on their base circle when the piston is at TDC?....
Old Jul 24, 2017 | 10:31 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
In that position #6 is at TDC compression. Need to turn crank 360* to get #1 to TDC compression.
JIM
Old Jul 24, 2017 | 10:33 PM
427Hotrod's Avatar
427Hotrod
Definitely something out of whack on valve adjustment. Start from #1 TDC compression stroke and do one cylinder at a time.
Look up the EO/IC method. It's the most foolproof way I know.
JIM
Old Jul 24, 2017 | 10:44 PM
stingraymaniac
Right now I have all the rockers of and just adjusting the number 1 cylinder and it still locks the engine when I adjust to zero lash, spins freely when you adjust like 1- 2 mm lash but then when you get into tolerance it locks up.. ?
Old Jul 25, 2017 | 02:59 AM
stingraymaniac
JIM
I have done it that way
To Camshaft problems..
Old Jul 25, 2017 | 05:40 AM
c3_dk's Avatar
c3_dk
This i TDC @ cylinder 6
If you want to be @ TDC on cylinder 1, then the dots must be @ 12 and 12 not 12 and 6
Old Jul 25, 2017 | 05:51 AM
stingraymaniac
The comp cam install manual says you shall install this way to have the cam at 0
Old Jul 25, 2017 | 07:36 AM
leadfoot4's Avatar
leadfoot4
With all of the rocker arm nuts installed, but relatively loose, can you rotate the engine freely?
