diff oil
Old Jul 25, 2017 | 01:09 AM
Dirk76's Avatar
Dirk76
Default diff oil
I have a rebuilt diff. Car will not be running for around 1 more year. Frame off.
Should I put oil in it.
It gets moved around 15 feet once a week at least.
Old Jul 25, 2017 | 02:52 AM
NONN37's Avatar
NONN37
i would. It will prevent surface rust forming and keep the bearings and discs clean as well as keep the seals from drying out.
Old Jul 25, 2017 | 03:14 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Also add the posi additive. T
Old Jul 25, 2017 | 05:17 AM
Dirk76's Avatar
Dirk76
cool thanks.
Old Jul 25, 2017 | 08:05 PM
ddawson's Avatar
ddawson
My new rebuild came dry but it was still oilly coated inside.
If the posi is pre lubed just add a qt and shake it around. Then when the time comes add the posi lube and top off to the correct level.
Old Jul 25, 2017 | 09:22 PM
ignatz's Avatar
ignatz
Excellent time to install a drain plug.
To diff oil
