I need to open my headlights to do some work.
Can I hook up to a certain vacuum hose/hoses to up the lights.
I tried hooking up to the vacuum actuator pod and I couldn't get it to raise.
I was using a Mytee Vac to supply the vacuum source. Is there a way I can get them to go up without the engine running?
You should be able to pump the headlights up and down with your Mityvac provided the actuator is not leaking.
I used to do this all the time with my wiper door when I was working on it to get it to function properly. Wiper door and headlights all work on the same principle.
Or if the vacuum hoses are disconnected you can raise and lower the headlights by hand. Just don't pull on the plastic headlight warning switch as it will break.
Just reach underneath the unit and push up on the pivot point of the mechanism and the headlight will rise and lock into place. Just be careful you don't push on the plastic headlight position warning sensor as they break very easily. You don't have to disconnect or change any lines as it was designed to work like this.
Grant and Richard hit it on the money...that is by far the easiest way without trying to "make" vacuum. What makes it even easier using that method is disconnecting the hoses from the headlight actuators, so you are not getting any resistance through the vacuum lines...they'll pop right up for you. Reverse the procedure to lower them.
Hi,
When reaching up from below to manually open or close the headlight doors it's important to NOT grab or push on the headlight warning switch by mistake. (It's located right where most folks reach to open or close the doors.)
The headlight switch is made of plastic and it's VERY EASY TO BREAK IT.
So use caution!
Push or pull on the rods… not the switch.
Pull forward and down to close.
Push inward and up to open.
Regards,
Alan
