Odd fuel leak
Old Jul 29, 2017 | 09:50 PM
68notray's Avatar
68notray
Default Odd fuel leak
I noticed a gassy smell in the garage lately. On my 69 big block, fuel is leaking from my fuel pump around where the steel bottom is crimped to the cast aluminum top. I've not seen that before. Obviously not repairable though. Anybody ever seen the same issue?
Old Jul 29, 2017 | 09:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by 68notray
I noticed a gassy smell in the garage lately. On my 69, fuel is leaking from my fuel pump around where the steel bottom is crimped to the cast aluminum top. I've not seen that before. Obviously not repairable though. Anybody ever seen the same issue?
Yes.. More times than I'd like to say... more than likely time for a new pump...
The diaphragm is leaking and fuel is getting past it coming out from the crimp.
Willcox
Old Jul 30, 2017 | 09:40 AM
68notray's Avatar
68notray
Ok - time for a new pump. BUT I must have had the wrong one anyway - all the pics I am seeing have the inlet pointing to the rear of the car and mine was pointing forward. Is the rear angle correct? If so do I need the moulded "S" hose?
Old Jul 30, 2017 | 09:49 PM
0Willcox Corvette
Former Vendor
That depends on what HP car you have.
I don't show the 69 using the S hose? 69 hoses were straight.
To Odd fuel leak
