Replacing crank sensor .
Old Jul 31, 2017 | 06:38 PM
aeckwood's Avatar
aeckwood
1st Gear
Default Replacing crank sensor .
I just purchased a 86 Iroc with a rebuild 350 vortec. Started leaking oil from the bottom from of the motor. I have been told it is a crank sensor. Oil pressure drops when I'm not pressing on the gas. I can see where the oil is leaking from and can touch it, feels like a loose rubber filling. Can someone help me figure this out? New to this and to working on cars. Got an older car to help me learn.
Old Aug 1, 2017 | 10:46 AM
MelWff's Avatar
MelWff
you do realize this is a Corvette forum and the area you posted in is for 68 to 82 vehicles which did not use crank sensors.
Old Aug 1, 2017 | 12:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Try these folks: https://camaroforums.com/forum/
To Replacing crank sensor .
