I have a front brake squeaking while driving. It goes away when applying the brakes. I checked the rotor for runout with a dial indicator the best I could on a drilled and slotted rotor. It looked to be within specs.
I cleaned and greased the pin that holds the pads up. The sound decreased in noise level but is still there. And it took driving it a few miles before I could hear it again.
This is a common problem. Auto parts stores have little squeeze packets of 'goo' that you use to apply "stripes" of the stuff on the backside of your pads. Let it dry and insert the pads. The stuff acts as a vibration damper between the piston surface and the pad face. It eliminates that nasty squeal.
yes you can use the spray can, just take the pads out put them pad side down on some cardboard and spray the back side really good
let it dry them re install them
Brakes should not squeal without applying pressure to the pedal. Disk brake quieting products should have no effect on the noise as described. There's only a tiny bit of pressure on the disk from the pad when the brakes aren't being applied (and only if you're still running calipers with lip seals with springs). There's something else going on, wheel bearing maybe.
Do you just apply it to the back of the pad. I have a spray can of that stuff. Just have never used it
Just put a squeeze dollop or two on the back of the pad and smear it
evenly around with your finger. Let it set up for about 10-12 minutes and your good to go.
Bearings are new. Squeak was there before and after bearing replacement.
Brake pads "should" be quiet doesn't mean that they are. This has always been a [minor] problem with the C3 brakes. Simple fix if you apply damper goo to the back of the pads when changing.
I've had no luck with the silicone based "goo" on the back of the the pads on the vette. I think the squeak has a lot to do with the disc surface condition and the type of pads being used (ceramic, semi-metalic, organic) as well as the condition of that pad based on the type.
On mine the disc is OEM and it has a pretty glazed surface. The pads are still from the PO 7 years ago and still have plenty of wear left and perform good enough for me to not be inclined to change them.
What I have done in the past is take the pads off and rub them face down on some heavy grit sand paper on a flat surface. 60 grit or so. Just enough to take the glaze off of the pads themselves. This solves the squeak for a time. Since the car is occasional use I believe this contributes to the glazing and resulting squeaking problem from moisture. They just don't get hot enough often enough to keep the pads in good shape I'm guessing.
Resurfacing the discs along with the pads would probably be better. Don't really want to have to take metal off the discs unless I need to though.
Forgot to add I also just barely round the edges of the pads if they are squared off at a sharp 90* angle to the disc. Enough to sort of intersect the disc at a more acute angle that may be less conducive to causing it to chatter (squeak).
