Need help figuring out an issue
Old Aug 1, 2017 | 04:55 PM
Robert Walsh's Avatar
Robert Walsh
Cruising
Default Need help figuring out an issue
Hi I have a 79 corvette that has some issues and I was wondering if I could ask someone a few questions to try and figure out what the issue could be, the car runs and idles pretty good but as soon as I put it into anything other than park it just looses all power I can rev it to keep it going but it'll continue to bog out. I'm only 17 so I'm not so experienced with these things so any help would be appreciated.
Thank you
Old Aug 1, 2017 | 06:14 PM
OldCarBum's Avatar
OldCarBum
Welcome to the Forum.
People will need to know details like, engine type, engine modifications, has this been an ongoing issue or something that just started and maybe any work to the car you have recently done.
Old Aug 1, 2017 | 06:22 PM
Robert Walsh
Cruising
Well it's has the l82 engine and the only thing I really know that was done to it is that it has an aftermarket air filter and big cooling fan and radiator which I'm not certain if it's stock or not, I was practically given the car yesterday so I'm just figuring everything out
Old Aug 1, 2017 | 06:23 PM
Robert Walsh
Cruising
Oh and it has the three speed automatic
Old Aug 2, 2017 | 11:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You also need to let us know what RPM it is idling at and when the last tuneup was. When you Rev it, what is the lowest rpm it will stay running at?
It could be something as easy as the idle set to low, a vacuum leak because a vacuum line is disconnected, in need of a tuneup, the timing is way off.
talk to whoever gave it to you and see if they've got any maintenance records.
I would first, change the oil. Then go buy an old shop manual that has the specifications for your years tuneup. You'll need to get a timing light( I would get a digital one with a tach setting and adjustable advance) at a minimum depending on the distributor that your engine has. If it's an HEI then that's it, if it's a points distributor you'll need a dwell meter too. You also need a points/spark plug gapping tool and a good basic set of tools and a set of jack stands
Old Aug 2, 2017 | 12:38 PM
Robert Walsh
Cruising
Well that's my issue too only the speedo works so I can't tell the rpm but it seems to idle kinda low so I'll try and get it to a higher idle and see if that'll help.
where would I have to check for the vaccum lines cause I'd like to try the simple things I can do myself with the tools I have here before running out and getting things considering funds are pretty tight for me haha. Any information helps a lot
Old Aug 2, 2017 | 12:50 PM
Robert Walsh
Cruising
I'm not sure if my last post came through but if it didn't Ill just re write it, I'm not sure if this could cause any issue but i found that's it's missing the fuse for the electric chock and heater
Old Aug 2, 2017 | 12:54 PM
Robert Walsh
Cruising
where would my best bet be for looking for a vaccum leak I've tried and looked it up but I can't figures the scamatics out half the time. Another thing is that the headlights don't go up and I saw on some pictures that the vaccum lines seem to go to them also, could that be an issue
I'm trying to figure out if it's an issue I can fix today without going to get anything else funds are pretty tight
Old Aug 2, 2017 | 01:25 PM
scrappy76's Avatar
scrappy76
Should be HEI ignition for that year unless someone changed it. Was the car sitting for awhile ? Could have bad gas,clogged fuel filter, or carb. I would start with a tuneup including changing plugs,wires,cap and rotor,oil and filter. Also change the fuel filter. I have seen weak coils in the cap cause issues once under load. How much gas is in the tank ? Is it missing or stuttering when you are trying to go? or does it bog down as if your dragging a ship behind you ? If it's bogging like trying to drag a ship, you might have brakes dragging bad.
Just read your post about the choke fuse missing. remove the air cleaner and check and make sure your butterfly on the carb is not closed or almost closed. with the engine warmed up, that butterfly needs to be straight up open.
Old Aug 2, 2017 | 05:04 PM
Robert Walsh
Cruising
So what happens is I'll put it into say drive and as soon as it leaves the park position it bogs out but I can like put it back into park and it'll idle
Old Aug 2, 2017 | 05:15 PM
blue by you's Avatar
blue by you
how is it after it warms up
Old Aug 2, 2017 | 06:09 PM
OldCarBum's Avatar
OldCarBum
Please do us a favor. open the hood, remove the air filter and take several photographs of the engine compartment from the front and both sides, then down from the top so we can see what is under the hood. I'm guessing you have very limited knowledge about vehicles or how to repair them. At least with the visuals it could take much of the guess work out of it for those why are willing to help.
Old Aug 2, 2017 | 06:50 PM
Robert Walsh
Cruising
Hey everyone thank you all so much for the assistance with this I'm new to most things but really interested in learning, I've been very busy today and haven't been able to repsond how I'd like to but I'll take the pictures and such soon and read all the responses. I'm so shocked by the amount of help this all has been I though no one would answer me haha
still figuring out the forum ha
Old Aug 2, 2017 | 06:53 PM
Robert Walsh
Cruising
Oh and In respsose about how it is after it warms up it pretty much idles the same and it still doesn't wanna be sitting still while in say reverse it'll instantly start bogging out
Old Aug 2, 2017 | 06:56 PM
Robert Walsh
Cruising
There's also two wires that I'm curious about cause ones not conected which the guy told me is for the headlight system but he didn't really tell me much and the other is literealy just a cut wire and he doesn't know what it's for I'll point them out with pictures later today or tomorrow morning if the rain doesn't stop tonight
Old Aug 2, 2017 | 09:16 PM
7T1vette's Avatar
7T1vette
Robert...
The most likely items to check out would be:
1. Does the car still have its original catalytic converter? If so, it may be plugged up and unable to pass exhaust gasses. That will bog an engine down big time!
2. The fuel filter (inside the carb inlet housing, if it still have the Quadra-Jet carb, could be plugged up and preventing adequate fuel from entering the carb. Be sure to use TWO adjustable wrenches to loosen that outer nut. You MUST hold the carb nut hex with one wrench and use a "line wrench" (six-sided box wrench with a slot to fit over the fuel line) to loosen the fuel line nut. Otherwise, you could fracture the carb housing.
3. Less likely...but possible...is that the torque converter on the transmission is damaged and will not transfer power from the engine well.
Old Aug 2, 2017 | 09:54 PM
Robert Walsh
Cruising
Originally Posted by 7T1vette
Robert...
thank you so much man first thing in the morning I'm going to go and see about the first two and see if they could be the issue, also thanks so much for being descriptive it really helps me
i really hope it's not the torque converter cause that would suck for me haha oh and I'm pretty sure it is the stock catalytic converter
To Need help figuring out an issue
Old Aug 3, 2017 | 09:22 AM
biackbenz's Avatar
biackbenz
Hey at least it starts and runs little. My first thought is a fuel problem. Run it for a few minutes. Let it sit for a few more. Loosen the nut on the fuel line at the carb. If fuel sprays out you can assume the pump and fuel lines are good. Oh by all means only use FLARE wrenches. Cost a few dollars but you don't want to mess up those nuts. If ready rusty get a can of penetrating oil and soak those nuts for a day first.
While your at it might as well re.love the fuel line to gain access to the fuel filter and change it.
Next look at that choke. Read up here about electric and hot air chokes. My 78 has a hot air choke. Not sure about 79. Sounds like you have an electric choke. Lots of guys made that simple conversion. If you have wires to your choke it is electric. If a wire is broken it is Not working. A closed choke will make your engine run like you describe. Lots of info on the forum about this
So far your biggest Cost is for those FLARE wrenches.
Next check for vacuum leaks. That is so much fun it calls for its own thread.
Old Aug 3, 2017 | 02:34 PM
Robert Walsh
Cruising
thanks man I'm gonna go out and start toying around with all the suggestions I've been given
Old Aug 3, 2017 | 06:23 PM
Rescue Rogers
A vacuum leak would sound like a high pitched suckling noise, you should have some rubber hoses on the front of the carburetor that go to the distributor and a valve or 2. Just look for small diameter hoses or thin nipped on the front of the carb and the intake behind it. If you have starting fluid you could do some very short squirt around the carb and behind it. If the engine jumps up in rpm it has a vacuum leak in that area
