Tack Weld Oil Pickup to Pump?
I installed a new Melling oil pump and pickup and the engine's now all buttoned up, but still on the stand. I installed the oil pickup using an open-end wrench and punch. It's in really, really tight and didn't give it a second thought, but just read where some people tack weld the pickup to the pump. Obviously this is to prevent movement but wondering if it's a necessary precaution or not. The engine's still on the stand so now's the time to do it. I don't have a welder but know someone who does. I appreciate any advice.
I always tack mine, but as you noted, they're usually really tight. I install the pickup, mount the pump with a fat wad of clay on the face, then set the pan with no gasket. Seat the pan and pull it off to see how far off the floor of the pan it is. If I need to adjust it, I do and recheck. When it's where I want it. a couple of quick hits with a MIG welder and done.
GM never welded one in FWIW>
I set mine at 3/8. I think the manuals say 3/8 to 1/2. But remember, I have a Moroso pan and the correct rectangle pickup for that pan.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Tim.. while I think the drive in place is fine, I always tack weld them... just in case.
Ernie
Ernie
Thanks all for you comments. I'm now sufficiently nervous with the "as-is" installation to do something about it so I will get it tack welded. I'm still curious if the retainer product, https://www.summitracing.com/parts/pio-839061, will work on the BBC Melling pump, M77. I'm guessing not but if anyone has any experience, I'd be grateful.
BTW-- I wear a belt AND suspenders.
The factory tacking one in must be a new thing- I worked in dealers from 1972 to 1988 and never saw one that was welded in. I don't recall ever seeing one that fell out either
On one that would pretty much just slip into place, I cleaned it and used blue Locktite. Later, I removed it and it was a bugger to get out. I used the Oxy-acetylene torch and heated the pump cover until it was almost glowing to get it to let go. So, I just do it that way now.
I found the pump cast cover just doesn't tack weld with a MIG very easily or nicely.
I have a melling select pump and a milodon pan. The pick up has a way to bolt it to the pump housing so I red loctited the tube and the bolt. Other than that I've either fully brazed or fully welded them.
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
I've had one fall off that was tack welded in place, it laid in the bottom of the sump with no damage to the engine.
I made a bracket like the one in the link and bolted the new one in place with locktite
Must pumps are cast and do not take welding very well, brazing would be the best way to do it if you choose to tack it in place.
Neal
Neal
I always braze the ones I install...and generally use Safety-silv 45 from Harris.
DUB
DUB
