Spark plug fouling- 1971 350 engine
Old Aug 13, 2017 | 08:09 PM
terry Richardson's Avatar
terry Richardson
5th Gear
Default Spark plug fouling- 1971 350 engine
What would cause the spark plugs to be tan half-way around the anode and oil coated on the other half of the anode? This is common to all spark plugs. Valve guide seals replaced last year, 2016. Piston rings condition unknown. Cylinder compression between 175 and 180 psi on all cylinders. Car runs decent and no discolored exhaust. I have tried different brands on plugs, have E3 installed now with same results.
Old Aug 13, 2017 | 10:02 PM
zwede's Avatar
zwede
Oil is making it past the piston rings, goes up into the intake during valve overlap and then back into the cylinder hitting one side of the plug. If your oil turns black very quickly after you change it, that's further indication of a ring issue.
That's assuming you checked the easy stuff like a stuck PCV valve.
Running a hotter plug and thicker oil will help.
Old Aug 14, 2017 | 09:34 PM
terry Richardson
5th Gear
Thanks.
I'll check PCV valve.
It's about time for an oil change, I'll try a heavier oil
Old Aug 15, 2017 | 08:25 PM
gkull's Avatar
gkull
You need to do a leak down test to tell you engine health. compression testing is a waste of time and effort.
Old Aug 15, 2017 | 09:40 PM
VERYSOON's Avatar
VERYSOON
Not an expert by any means but I have read that is a classic sign of bad valve guide seals. Maybe the 2016 install was not correct!
VS
To Spark plug fouling- 1971 350 engine
