Speedometer needle bouncing
Old Aug 13, 2017 | 09:24 PM
Bigdade's Avatar
Bigdade
Default Speedometer needle bouncing
My 1980 c3 speedo is making a clicking noise and bouncing.Its also about 10 mph too fast.Trip and odometer are working.Any ideas?
Old Aug 13, 2017 | 09:32 PM
terry82's Avatar
terry82
lube speedo cable.
Old Aug 14, 2017 | 07:13 PM
tehjrow's Avatar
tehjrow
I pulled the inner cable all the way out, used dry graphite lube, and slid it all the way back in.
Old Aug 14, 2017 | 08:38 PM
M Pete's Avatar
M Pete
Or pay about $10 for a new one, install is pretty easy. Is the clicking coming from under the car? If so I'd recommend getting a new cable because that is the cable slipping in the plastic gear in the transmission which I would imagine eventually ruin that as well.
Mine was clicking after my original cable broke and it turns out that my cruise control is locking up so I just ran the cable straight from trans to speedo.
Old Aug 14, 2017 | 09:40 PM
Victor's Avatar
Victor
I believe the bouncing is an indicator that the speedo cable is on the way out. Mine did that for about a year before the speech actually stopped working. I'd just buy a new one rather than try to fix it.
I wish I would have paid attention to this when my speedo stopped working, but am I correct in assuming that the speedo cable also controls the odometer?
My '79 had the TH350 (automatic) and If I recall correctly the only connections to the transmission were the cable connecting the shifter to the trans, a vacuum hose, the speedo cable, and a kick-down cable that connected to the throttle linkage on the carberator. So the odometer would have to be driven by the speedometer cable??
To Speedometer needle bouncing
