ive got a 69 thats pulling to the left, hard, under braking. ive got new rubber brake lines on both fronts and new calipers. neither has made a real difference yet. also have put a new MC and freshly rebuilt booster on a few years ago. pads and rotors are a couple years old too, but still like new.
the lines have been bled, stopping power is excellent, and the brakes feel excellent, with the notable exception that the car pulls hard to the left still. its better with all the new gear, but its still an issue
ive checked the suspension components (all new within the last 6-7 years) and everything is fine there.
which leaves me with pressure checking the lines them self. im hoping to see if both sides are equal, or if the drivers side is much lower than the pass side.
Not that this is your problem, but when my 69 started doing something similar a couple of years ago, pulling to the right when braking, it turned out to be the front tire was delaminating. A new set of T/As and all was good again.
Just something else to check.
Hi a-u,
The hard line from the distribution block to the left side rubber line connection is a very short one.
Have you, or would you consider, changing it?
Being so short it's pretty easy to develop a 'kink' in it.
Regards,
Alan
Is there ANY chance that's it's a problem with the RIGHT side NOT functioning?
definitely a pressure test would help isolate the issue. there is a tool for that, you need to find a shop that has one. you can't just stick a guage on a Tee in the line, as there are many variables beyond which affect actual pad clamping force. (piston COF, bracket flex, caliper flex, etc.)
Waekon and OTC both make one, look for a shop which has a brake pressure equalization test kit.
alan may be onto something here. I was thinking along the lines that maybe the runout on the right side is excessive. This spaces the pads out farther on that side making the left side grab first.
Tires - ive already rotated them, no change, so the tires are fine.
metal brake line kink - this is something ive considered. kind of a last resort thing i think, as the lines are all original and i see no reason they should have kinked after 40 years problem free.
right caliper not working - doubtful, i have wear marks on those pads and rotors.
left caliper - unless ive picked up multiple bad ones, theyre working fine. the original set worked fine but had the same pulling problem. new ones worked fine (except one of the new ones is leaking, so i RMAd it and will be putting a 3rd one on this evening)
so i think the best thing i can do at this point is pick up a pressure gauge and test out the line pressure.
Hard pull left almost always indicates an issue with the passenger side as the driver's side is working and applying the stopping/pull to that side.
Total shot in the dark here but I had a similar but different issue a while back on the heels of replacing 4 rotors, fluid, and pads. In my case the car pulled even with the brakes off. I turned out that I had a very slightly bent spindle likely from a fender bender by previous owner. With the old rotors there was enough play for it to 'wobble' and not bind up but with all new hardware, there was no room for play and the brake pads were effectively engaged a bit when everything was bolted up tight. But I couldn't see it with the naked eye. But you could sure feel the overwhelming heat pulling the wheel off after just driving a few hundred yards to test. We swapped out the spindle from an old car and the problem was solved immediately.
Does it pull left only on the first application during a stop and if you let up and apply the brake again it brakes straight ahead, or does it continue to pull left on the second application?
