69 Vette has A/C again
Old Aug 16, 2017 | 09:07 PM
VERYSOON's Avatar
VERYSOON
Default 69 Vette has A/C again
Decided to try to get A/C going in the Vette I bought 8 months ago. Previous owner said he has not tried it in 40 years!!
Pulled a vacuum
Would not hold vacuum
Put all new seals in A6 compressor. It really was not hard. $22. A little blood too removing compressor.
Put new green o-rings in all points I could reach without removing hood.
Now she holds a vacuum.
Put some freon in. Enough to leak check. No leaks. Put some more in.
I find low side pressure goes to vacuum and high side under 100 psi.
Figure there is a block and put in new expansion valve. $58. Could not blow through old expansion valve. Encouraging.
And new receiver/drier from Zip. Like original. Another $58
Charged with 3 pounds R12. Its now koool inside!!
I encourage anyone to try and get their old a/c going and stick with R12!
Love this car.
VERYSOON
Old Aug 16, 2017 | 09:58 PM
ChromeBumperGuy's Avatar
ChromeBumperGuy
This is encouraging! I have a '71 with factory air but not cold. I just finished a rear end rebuild/restore, AC is high on my list for next system to tackle. Thanks for the info!
Old Aug 17, 2017 | 08:11 AM
maj75's Avatar
maj75
Getting ready to do mine. Not looking forward to it as there isn't a whole lot of room for my big hands with the 427 and smog stuff crammed in there. I did discover that one of the two main AC hoses is cracked clear through. I think that hose is actually a 2 hose combo with a mounting block. It's expensive and I haven't seen one for the '69 that fits right.
Old Aug 17, 2017 | 10:25 AM
dyerk's Avatar
dyerk
I have a 69 A/C car but someone stripped all my A/C parts.
Old Aug 17, 2017 | 08:49 PM
mortgageguy's Avatar
mortgageguy
Did you have any problems removing the poa valve?
Old Aug 17, 2017 | 10:15 PM
VERYSOON's Avatar
VERYSOON
I did not remove the poa valve. After lots of study online I decided not to disturb that item except I did put in a new Schrader valve. Figured a frozen evaporator would be a welcome problem!! heehee!
But if you wanted to remove it and have it checked out it looks about the same difficulty as the expansion valve. I had the old expansion valve out and new one in in less than 15 minutes. Did not want to expose the new receiver/dryer to an open system any longer than necessary.
My main concern was with the condenser. But it didn't leak so I rolled the dice on whether it was stopped up somehow. Pressures are textbook so its okay. I would advise anyone doing this to replace the expansion valve along with the receiver/dryer. its easier to do than the receiver and its about the same cost. Main leak in the system was the usual suspect, the old compressor shaft seal.
As to charging, I put 1.5 pounds R12 in and let the system cool down and sit overnight. Next morning a put a fan blowing on the condenser and radiator and the next 1.5 pounds went in easy at about 1500 rpm.
Ccccold here in Texas!!
VS
Old Aug 17, 2017 | 10:38 PM
BLUE1972's Avatar
BLUE1972
To 69 Vette has A/C again
