Clutch adjustment
Old Aug 18, 2017 | 09:01 AM
Nsarge's Avatar
Nsarge
Default Clutch adjustment
Just bought a very nice 71 with a slightly built 350, 4 speed. Original 270 hp block, original transmission. The transmission has been rebuilt and clutch, pressure plate, flywheel replaced. Everything feels good and works nice except there is no adjustment left to get the clutch petal up off the floor. It must be pressed firmly and fully to the floor to shift. The adjustment is all the way at the end of the pushrod. It seems as though the fork pivot ball is too short, but.... Also there isn't a feel of perceptible excessive free play at the top.
I don't understand why the stack up would have changed based on what I think I know about the replaced components.
Any ideas?
Many thanks.
Old Aug 18, 2017 | 09:37 AM
Alan 71's Avatar
Alan 71
Hi Ns,
Welcome!
First Post!
And a 71, very nice.
Do you know about the GM Assembly Instruction Manual and the clutch adjustment procedure in it?
Perhaps in looking at that you'll spot something amiss.
Regards,
Alan
Old Aug 18, 2017 | 10:51 AM
Nsarge's Avatar
Nsarge
Alan I really appreciate the quick reply. I'll go over all this and see if something reveals itself. Having been through several clutch projects over the years this one has me baffled at this point. It's really not 'car rocket science' if you know what I mean. Everything appears ok just from a visual perspective, except whereas your last photo shows several threads sticking out the pushrod shaft, mine has none!
Old Aug 18, 2017 | 03:17 PM
Alan 71's Avatar
Alan 71
Hi Ns,
What does the angle of the clutch arm coming out of the bell housing look like?
Regards,
Alan
Old Aug 18, 2017 | 04:39 PM
brentw's Avatar
brentw
Great information. I'm having the same issue. Only mine grinds really bad going into reverse.
New clutch, Bearing, etc. 1st through 4th good, But pedal is pushed all the way in. When shifting into reverse Grinds bad.
Old Aug 18, 2017 | 05:41 PM
Griff2002's Avatar
Griff2002
https://www.corvetteforum.com/forums...and-specs.html
There was some good information in this thread about a potential cause for clutch adjustment problems. Not sure if I pasted the link correctly but if it does not work you can do a search for it.
Old Aug 18, 2017 | 06:27 PM
Shovels and Vettes's Avatar
Shovels and Vettes
I found the AIM procedure did not work on my clutch. I simply had to adjust the clutch pedal in a position that worked, and it was nowhere near the position the AIM suggested. I have a SPEC clutch, and factory GM throwout bearing, arm, etc. I can't explain why.
Old Aug 19, 2017 | 07:28 AM
Nsarge's Avatar
Nsarge
Originally Posted by Alan 71
Hi Ns,
Regards,
Alan
Well I think you're heading in the right direction. My arm (fork) isn't nearly as 'flat' to the side of the bell housing as depicted in your photos. (BTW that's a BEAUTIFUL restoration!). And notice on your cross shaft vertical arm that's connected to the fork push rod - your arm is angled towards the front while mine is nearly vertical; all of which makes sense as to my problem of the adjustment being all out.
Sooo, - in poring through old receipts I learned it is a Hays clutch kit - pressure plate, clutch, and TO bearing. Flywheel was replaced too. The receipt makes no mention of changing the pivot ball or fork arm. And the previous owner was pretty **** about putting in the right part numbers etc.
However I read a cautionary note somewhere that it is easy to get the wrong throw out bearing and I'm kinda focusing now in that direction. It will be a few weeks before I can get the transmission out for closer looks. I'll try to find this thread and report what we find.
Thank you thank you Alan, and the others, for the input.
Old Aug 19, 2017 | 07:38 AM
Nsarge's Avatar
Nsarge
Wow, there's some good info there too. And mine is a Hayes...
Old Oct 17, 2017 | 08:42 PM
Nsarge's Avatar
Nsarge
Ok got it all out. Overall height of the TO bearing is about 1.195". I have a manual that says it should be 1.250".
The fork pivot ball measures 1.375". All my parts catalogs seem to imply it should be 1.250". Would anyone have any thoughts on that?
Old Oct 17, 2017 | 08:43 PM
Nsarge's Avatar
Nsarge
Correction - pivot ball catalogs say 1.500", not 1.250. (Can't type)
Old Oct 17, 2017 | 10:11 PM
croaker's Avatar
croaker
My 75 has the same Hays clutch in it the throw out bearing came with the clutch. I had to install a new GM fork as my spring busted. I measured what I had and the
new setup were almost identical. My adjustment is right at the end also. They make a extended adjustment arm. Just so you know your not alone.
Old Oct 18, 2017 | 09:56 AM
20mercury's Avatar
20mercury
Default my experience,...
On my 68 with a 454, I was out of travel/threads to adjust the clutch rod any further, so I installed a C2 clutch rod which was a little longer and had plenty of length to get the clutch where it needed to be to disengage properly.
Who knows why, 454 is obviously not original, maybe the location of everything was slightly off, maybe wrong clutch fork (but looked ok to me), but it works great now.
Great link, Lars always has great info and good to know about the "hump" and over travel. Hope this might help too if all else fails.
Old Oct 18, 2017 | 11:59 AM
Nsarge's Avatar
Nsarge
Appreciate all the replies to this point. Part of my dilemma to be clear is that even with the adjustment fully out I have virtually no free play at the top. So now I’m beginning to think more about the Hayes pressure plate may require more travel than this vintage of Corvette can manage. (Re: Lars posting). I’m assuming when these cars were new they had good pedal travel, good free play at the top, and good release without having to cram your foot through the floor. I’m gonna figure this out!
Old Oct 18, 2017 | 03:15 PM
buns's Avatar
buns
Nsarge, is your new flywheel also made by Hayes? The one I bought was quite a bit thinner than my old stock one. That required me to use an adjustable pivot ball.
Some info from Centerforce:
Old Oct 18, 2017 | 11:50 PM
TimAT's Avatar
TimAT
The PO of my 69 had installed a Lakewood bell housing way, way before anyone had any idea about clutch pivot ball height. He used the factory pivot in the Lakewood. Clutch was fine, but there was very little room for adjustment. Spin forward 30 years- I built a new BB, that required a new flywheel that turned out to be a whole lot thinner than the factory one. Measured the ball height from the same sheet buns posted above. Set up the new pivot ball from those measurements and the clutch adjustment, (new Centerforce DF), moved the adjustment over halfway up the threads instead of it being within the last 1/2".
Old Oct 19, 2017 | 09:57 AM
Nsarge's Avatar
Nsarge
One more question - the rod from the cross shaft to the clutch fork is worn oblong (which affects the overall adjustment, but not the total travel) which seems odd. Almost like that rod is too soft.
Can I just weld and repair the hole, or does somebody sell one that’s harder?
To Clutch adjustment
Old Oct 19, 2017 | 10:41 AM
MelWff's Avatar
MelWff
Default reverse
are you aware that the transmission is supposed to be shifted into a forward gear and then shifted into reverse due to the lack of synchros on reverse?
Old Oct 19, 2017 | 11:50 AM
CanadaGrant's Avatar
CanadaGrant
I had the same problem with my 69 427. The threaded rod was at the end of adjustment but the clutch worked just fine. When I had the engine out I replaced the clutch, flywheel, pressure plate and throw out bearing figuring it was just clutch wear. Nope, same thing... Rather than tearing everything apart I used a longer clutch fork pushrod from a 64 to 66 Corvette 327 that looks exactly the same right down to the spring holes for your stock anti-rattle springs but, it's 1.5 inches longer than the normal one on a C3. Overall length is 10.5 inches or about 10.0 inches center to center where the stock one is about 9 inches overall. It put the adjustment nuts right back in the center of the adjuster rod again. I attributed the problem to either an aftermarket clutch difference or throw out bearing difference but am not sure what the deal was. Both the old clutch system that was in the car and and new one were the same on lack of adjustment and rod position so it wasn't wear. Picture of the longer lower fork pushrod I used in the link below.
http://www.parts123.com/corvettecent...0050b&ukey=764
Old Oct 19, 2017 | 02:08 PM
croaker's Avatar
croaker
Back in the day they just welded on more threads. Not acceptable but,
