AC replacement / upgrade
Old Aug 19, 2017 | 12:58 PM
Majer3rd's Avatar
Majer3rd
8th Gear
Default AC replacement / upgrade
Hello,
I am refreshing my AC system in my 79 corvette with everything new. In the process I am upgrading to a Sanden 508 form the R4 compressor and replacing the condenser with a parallel flow condenser from classic air.
I know several C3 owners have upgraded to Sanden compressors, but has anyone installed them with a low mount where the mechanical fuel pump would be? If so, do you have any pictures and recommendation on the installation.
http://www.jegs.com/i/Vintage-Air/96...0-VCB/10002/-1
If I can use this low mount, I would need to upgrade to an electric fuel pump. What are the recommendations for a reliable pump that will work with the stock Quadrajet?
Old Aug 19, 2017 | 04:42 PM
BLUE1972's Avatar
BLUE1972
In tank is best, the Edelbrock or Holley frame mounts work well but are noisy - both are rated at 6 PSI.
Old Aug 19, 2017 | 11:51 PM
7T1vette's Avatar
7T1vette
Why would you want it down there? Yes, it's out of the way. But, when you need to work on it....it's out of the way!!
I bought the Classic Air upgrade kit and the brackets put the compressor down & in front of where the original compressor fit. No problem getting to plugs with that location.
I though about the low mount...and then decided better of it.
Old Aug 20, 2017 | 09:02 AM
Street Rat's Avatar
Street Rat
Top mount Sanden on my '81.
Old Aug 20, 2017 | 09:57 AM
Big2Bird's Avatar
Big2Bird
Craig, could you post a source for that compressor and brackets sometime. I'm on the road with the brand new R4, and it 3000 miles, it's already sounding like a bag of rocks.
Old Aug 20, 2017 | 02:22 PM
Street Rat's Avatar
Street Rat
I called Classic Auto Air in Florida. They sold me a kit with Alan Grove brackets which are awesome. They don't list the kits for the 80-82 in the catalog because the hoses have to be made up. CAA supplies all that you need. Hoses, fittings, brackets, etc.
Call Ron at (813) 251-2356 He should be able to fix you up.
Old Aug 21, 2017 | 09:01 AM
Majer3rd's Avatar
Majer3rd
8th Gear
Is that the 7 series compressor? I ordered a kit from them with the condensor and I requested a sanden compressor. I learned its not Sanden but sanden type 7 series.
I'm on the fence about it since I can get the vintage air Sanden brand 5 series rear exit compressor for 199 from jegs. They want 800 for their kit. I can save a few hundred if I go elsewhere.
Old Aug 23, 2017 | 11:24 AM
Majer3rd's Avatar
Majer3rd
8th Gear
I just picked up the kit from Classic Air.
New Sanden style 7 series compressor
accumulator and orifice tube
Parallel flow condenser
hoses with ends installed (Sanden ends not installed on hoses yet)
Sanden compressor compression hose ends.
Alan Grove compressor brackets
o-rings
$834 with tax
I also bought new evaporator, hard line, and wiring harness from online corvette parts. The entire system will be new
To AC replacement / upgrade
