My NEW and improved 383 CFI build
#42
Cruising
#43
Are Renegade ports the same size as the afr 195 heads
#44
The TBs flow 760cfm, flow verified on super flow SF-600 bench. Fuel system is my own version of parallel plumbing using external Aeromotive universal FPR, vacuum referenced. Running 24.5psi WOT and 18psi @ idle with 454 90# TBI injectors. The exhaust is Hedman headers with 2.5" SS true duals with X-pipe into Hooker max flow mufflers.
1. New GM SBC block - 383
2. New heads - AFR 195 Eliminators
3. New forged crank - Eagle
4. New forged pistons, Wiseco 10.5
5. New forged rods - 6" FSI I-beam
5. New cam Got rid of the Straub cam that was brand new with only one dyno pull and a 100 miles on it and installed a Bullet roller cam
6. New valve springs - LS
7. New coil and module - DUI
8. EBL Flash II ECM mod
9. Updated tune
10. Best time so far with this motor with only 840 miles on it was 12.73 @ 109mph, it still has more power in it for sure.
NOTE: Had tranny issues going into third, but I think I may have fixed that now and hope to do the 1st gear 700r mod and get the car down to 12.40-12.50 range, maybe even lower? Getting closer to Ben 73's 84 CF with his 12.20 pass. The motor is hauling *** and love the new power it makes. Hope this helps a bit more for you guys wanting to increase your CFI hp.
#46
I was going through some old posts and saw the one I made in 17 and thought I had updated this a while ago, guess not. OK, for all you CFI guys out there here are some upgrades I have done since this motor...in 18
9. Updated tune
9. Updated tune
What is this 1st gear 700r mod?
#47
It is the shift plate mod so you can actually put the selector lever into 1st gear and hold it to when you want to shift into 2nd vs only being able to put the lever in 2nd which is really 1st and the trans will shift automatically into 2nd, then you can hold 2nd into 3rd. I hate the no 1st gear hold out. Why GM made it that way is beyond me. With a 3,06 1st gear in a 700r4, that would have made for a much much better launch and shift vs current.
Oh, and one more thing about my fueling. I use the 255lph in-tank pump that is very quiet, just like stock to keep everything feed. The only time I hear it is when you first hit the key for a second or two at prime. Here is the link. 255lph pmp
#48
#49
Well, there is another 1st gear mod to the trans which is the planetary 2.84 conversation vs 3.06 which I have thought about doing also. If I pull the trans again, I may do that one as well.
#50
Has anyone else done the 2.84 1st gear conversion to their 700r4 and if so, did you see an improvement in ET? Thanks...
#51
Great thread!!!
Dear Bucc,
fantastic thread! I am in line to purchase an 82. My buddy is in the process of purchasing it now. I will be maintaining it for him.
He doesn’t expect to own it long. I’ve got 1st dibs on it.
When I buy it I want to do a similar job you did on yours. I’m an engineer by trade and especially the way you used the plumbing. Wow what a job! It always has appeared to me to be the weak spot for these aging cars. It may only be original one, but I want to see things run right!
your fellow enthusiast,
steve
steve
#52
I don't have to per-say, but it would end up costing me more than I want to spend on it again to go that little bit faster and then to do it right I would go with a 4L60E or 80E which then means a newer ECM and yet another tune etc... The cost keeps climbing. My 700 is pretty good other than the 1st gear nonsense which I plan on taking care of this winter and ready to go back to the track in Jan/Feb.
Thank you Steve and hope you pick up the CF. They are good cars once you sort em out, kind of like the energizer bunny, they keep going and going... Let me know when you get ready to do things to it and save you some time and money on the mods.
Dear Bucc,
steve
steve
#54
I'm going to try and make a short vid of my motor running for all the CF guys. Not sure when, but I will try and get to it this weekend and upload it to my site.
#55
Dear Buccaneers,
what is the latest on your 1982 CFI? I’d like to get in touch my buddies ride has issues. The idle is super fast I’m thinking vacuum leak. The hoses appear good. The headlights work great etc. the engine is running fair. No misses etc. My thinking so far on the car is the throttle bodies could stand some rebuilding...the car has about 55K miles and has set for long periods. Right now the gas tank is out with a hole. The gas that leaked out on my concrete left a nasty stain on it. I believe the gas tank was nasty. Another mechanic/ex-owner is trying to locate another one. What would you do to improve the way the car runs?
thanks!
Steve
thanks!
Steve
#56
Dear Buccaneers,
thanks!
Steve
thanks!
Steve
#57
Dear Buccaneers,
thanks!
Steve
thanks!
Steve
#58
I am not sure I see the "budget" in this, pistons need to be flycut at a machine shop, dry sump needs to be addressed somehow, you will need PCM tuning, etc. Your goal is to run 11's? Is that all motor? Did it run 11's before?
Don't let my comments discourage you, I am just trying to understand the big picture here. But I am one who will stuff a 427 into anything so don't mine me!
#59
My 82 best time is 12.64,at 3,600'-3,800'+ DA but that was last year and have not been back to date. I've made "some" changes, but not all of them since it's STILL hot as hell here in AZ in Oct. Hoping to do some other things before Jan/Feb time frame, but it may not happen with all this covid crap, delays etc... I would be "ecstatic" as hell at 11.99, but I don't think it will happen. Fueling and tuning limitation at this point. Maybe move to Haltech system in the future. Oh, and the motor is all NA, no boost or giggle gas.
#60
C3. 427, 4-link, c7 z06
I love your build probably more than anything because you used the stock /modified things setup. I had a friend with an 82 that had a stock tbi setup. Cosmetically it looks cool and unique. I can’t help but think your intake is a bit of a bottle neck but I see you had it flowed at 760 cfm. Do you run it with the air cleaner? That air cleaner has to have some restriction doesn’t it?
