Another head question.
My car is a matching numbers '78 with an L-48 and a 4-speed. I know from reading here that the intake and carb are more than adequate.
I just got a real dual exhaust that I'm installing it this weekend.
What I believe I need are better breathing heads. Probably 2.02 and 1.94's I'm guessing. Maybe 64cc to increase compression. But I want leaded pump gas.
I want sort of a stock looking car. I'm keeping my blue valve covers and black air cleaner. No headers no flash. I'll probably upgrade my wheels but that's another conversation.
So my question is this, I don't want to spend $1,000 on aluminum heads unless that's my only choice. I am looking to find out what used heads I should be searching for. I'm in no hurry. If it takes a year to find the right heads at the right price, I'm fine with that.
What I want are hands that give me the breathing and horsepower that I'm looking for that are direct bolt on using all the brackets and vacuum lines and all the other stock parts that I have.
Suggestions?
As far as used heads, by the time you have new guides, springs, retainers, seals and sometimes valves plus labor, well, you could purchase new for less. I question wether spending $1,000-$1800 for aluminum heads is a good investment just for street cruising from traffic light to traffic light. But thats just me.
Aluminum heads had a bad reputation years ago with warping, coolant seepage, bad valve guides, etc. Today the machining quality is much better as are the alloys. If you have access to YouTube check out some videos on ProMaxx heads being cross-cut in half to show the inside. Pretty cool stuff.
The carb (assuming it's the quadrajet that came on your car) is adequate. Plenty of people using them on engines in the 400+hp range so perfect for you.
The intake is NOT adequate in my opinion. Not only is it heavy (iron) it doesn't flow as well as a modern intake. Pick up a Edelbrock Performer aluminum intake with the spreadbore (Qjet) bolt pattern for $100 on craigslist or ebay. It will give you a little more horsepower and torque and remove some weight from the front end.
YES! Better breathing heads are key. The two best cheap options would either be the iron vortec heads or the 113 aluminum heads. Both have their own pros and cons (a quick search will help you decide what works better for you). But new heads will make the single biggest difference in your engine build.
I would also recommend getting some headers, the stock manifolds will be your next big restriction.
And finally a modern cam grind to tie it all together. I would recommend the Lunati 262, but their are a couple options that would work well.
All of that together should cost you somewhere around $1000-$1500 depending how good you are at finding deals, and your motor will be putting out somewhere over 300 hp easily. It will be night and day over your current setup.
For reference, I put Brodix Aluminum heads, Performer RPM intake, Lunati 268 Cam in my stock motor and it is a completely different animal. No more getting outrun by some bone stock sedan at the lights!
Make the jump to Vortecs with and Edlebrock Performer RPM intake and some type of block hugger/shorty headers like McJacks. You'll need to modify your exhaust down pipe for any type of 2.5" manifold.
This is also my very first (baby) step in a new build.
Edelbrock Performer 2101 (that's the spreadbore version) on Ebay for $100 clams. Keeping the Quadrajet.
-W
The performer RPM is definitely preferred if you can find one cheap! They aren't as common as the standard Performer, but they are definitely superior. Keep in mind, you need to use a drop base air cleaner to use the Performer RPM!
For what you're looking to do on a budget, I would be ok with the standard performer if you can't find the RPM for cheap. But the RPM would give you a couple more HP
rest of the info here http://garage.grumpysperformance.com...any-good.5521/
I've heard a lot about vortech heads but I'm not familiar with them. My last build was a '68 Camaro and double hump heads were the easy choice. With a '78, I'm a little less familiar.
Can anyone confirm that my order is correct and tell me a little more about vortech heads. Are there different ones?
I think most people do exhaust and intake first because they're easiest. A cam is no good if the heads cant flow it. Besides I think the big boy cam guys make cams to match the heads versus buying heads to match a cam
So that all being said, Exhaust, intake, heads, cam. Q-jet is just fine.
Vortec have revised runners postions. There are different ones but 062 and 906's are the 'off the shelf' ones to get.
Have fun: http://nastyz28.com/threads/vortec-c...e-guide.56505/
I would start with true dual exhaust (with headers) and the performer intake. Both of those are fairly easy and will net you some decent gains. MAKE SURE TO RECURVE YOUR DISTRIBUTOR! Do a search on here, there are a few how-to guides. It's pretty easy and will give you a significant increase in throttle response.
I would do the heads and cam together, you want your cam to match the rest of your build. The vortec heads have a different bolt pattern for the intake than other heads, so make sure you get an intake that is drilled for Vortec heads (should say in the description on any good parts site like Jegs or Summit). You CAN get Vortec heads from a junkyard for cheap, but you would have to have them checked by a good machine shop, so your best bet is to just find one of the places online that sells reconditioned heads. Most of them will even change the valve springs for you to match the cam you want to use. You can usually find them for about $600 for a set of heads if you search.
PM me if interested, I'm in Vegas. Shipping might be a killer depending on where you are.
Disagree. He has an L48 with the stock iron intake. Even a cheap performer dual plane will outperform it by a few horsepower AND take 20 pounds ish off the nose of the car. That is well worth the under $100 price tag, especially if he is planning to do heads/cam upgrade later on. That stock intake is going to become a big bottle neck fast with better flowing exhaust, heads, and a cam.
