Another head question.
I made 300 HP and 380 ft lbs with a truck cam, stock bottom end and these heads. The right cam would dial it up a lot. They flow better than vortecs, take your stock valve covers, intake and are economical. Have 430 HP potential.
http://www.ebay.com/itm/Chevrolet-35...hUkH4f&vxp=mtr
2 1/2" ramhorns and 2 1/2 free flowing dual exhaust at minimums. Headers are way better.https://www.summitracing.com/parts/s...make/chevrolet
I would upgrade to a Performer 2101 minimum, they will match up with the head ports well.
This cam should meet your needs and match the head spring rate although I hesitate to recommend anything but a roller. https://www.summitracing.com/parts/c...make/chevrolet
Use these lifters:https://www.summitracing.com/parts/c...make/chevrolet
Use these head gaskets: https://www.summitracing.com/parts/f...make/chevrolet
Or Use this kit if you want more lift. Springs fit pockets in heads. https://www.summitracing.com/parts/c...make/chevrolet
This winter will be new heads and headers. I'm going to keep these on my watch list and save my pennies.
Thanks again.
Using my secret formula involving CFM, RPMs, tire width and the like, a rough calculation would be a burnout tire marks measurement of 2.8 ft shorter.
