Replacing Wiper Switch Decal
Old Aug 24, 2017 | 09:48 PM
Reaper19's Avatar
Reaper19
Default Replacing Wiper Switch Decal
Has anyone replaced their wiper switch face decal? I have a 1981 and just purchased a new decal for the wiper switch, wondering if anyone has completed this job.
What is the best process?
How did you remove the old decal?
Old Aug 25, 2017 | 10:17 PM
Reaper19's Avatar
Reaper19
Bump!
Old Aug 25, 2017 | 11:04 PM
BlackC3vette's Avatar
BlackC3vette
Originally Posted by Reaper19
Bump!
Well, I was going to replace the one in my 80 until I lost the decal behind the abyss of my sons toolbox. Easier to buy another one.
Anyway, looking at the decal (when I still had it), I was going to slit it were the toggle path was to fit over the wiper toggle shaft. Then I was going to peel some of the backing to position it and then keep peeling and smoothing as I went. Unfortunately, I can tell you if it worked.
Old Aug 25, 2017 | 11:14 PM
Reaper19's Avatar
Reaper19
Were you going to try and remove the old one first or install the new decal over the original?
THX
Old Aug 26, 2017 | 02:14 AM
7T1vette's Avatar
7T1vette
If you have the original tag already, why do you want to put a "new" one on it? I only replace the ones that are missing.
Old Aug 26, 2017 | 08:38 AM
Reaper19's Avatar
Reaper19
The one I have is the original on the wiper switch and it is spider webbed. When the lights are on you can see the cracks. I wanted to replace and get rid of the cracked decal on the switch.
Old Aug 26, 2017 | 09:34 AM
Lakeside49's Avatar
Lakeside49
I replaced it recently for the same reason that you are (the wiper switch's backlight shines through the spider-webbing). It is actually a piece of cake.
1.) Remove the wiper switch bezel housing which pops off easily
2.) unscrew the round switch head
3.) perl off the old decal, including the blue plastic
4.) stick on the new decal
Old Aug 26, 2017 | 12:21 PM
BlackC3vette
THX
Yes, off with the old one.
Old Aug 26, 2017 | 12:27 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I make this part...
The main thing you need to do is make sure you get all the old decal off... and then make sure there is no debris left on the plastic face. If there is anything left on the face when you put the new one on it will show.
Willcox
To Replacing Wiper Switch Decal
