82 Corvette ECM
Old Aug 26, 2017 | 12:21 AM
woodywoodard's Avatar
woodywoodard
3rd Gear
Default 82 Corvette ECM
will my ECM cause a parasitic battery drain, unit feels warm
Old Aug 26, 2017 | 02:05 AM
7T1vette's Avatar
7T1vette
It's possible, but there should be no power going to it when the key is off. But, if it has some kind of internal failure, it could cause power bus to turn something on. You need someone with good diagnostic skills and equipment for that one, unless you just want to swap it out.
On the other hand, you need to be certain that some other switch/device isn't sending power to the ECM in error. Find the source of the power before you make any decisions to swap parts out.
