1970 Speedometer and Cable questions
Old Aug 28, 2017 | 02:38 PM
wer2xu's Avatar
wer2xu
Default 1970 Speedometer and Cable questions
In the midst of getting ready to start trouble shooting a bouncy speedo on a 1970 4sp LS5, two questions.
1. I see both two piece and one piece cables advertised for this car, my AIM is currently buried in a box, buried in a basement, what is correct?
2. I hear a clicking from behind the dash, what are the chances of a bad speedometer vs. cable?
Any input is greatly appreciated.
Old Aug 28, 2017 | 02:44 PM
TimAT's Avatar
TimAT
2 piece cables are used for cars with cruise control.
I'd have to go with a speedo problem, unless your cable is kinked. You can get the cable out without pulling the dash.
Old Aug 28, 2017 | 03:41 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Yes, one piece cable. Hopefully just that. You can unhook the cable sheath from behind the speedo by pushing in the tab and pulling back on the cable housing. Then pull out the inner cable from the housing and check it for condition. Unfortunately there are times when the receiver for the cable on the speedometer gets rounded off inside(instead of square) and the cable slips. Have to pull the gauge then and repair.
Old Aug 28, 2017 | 05:23 PM
Alan 71's Avatar
Alan 71
Hi w,
Here you can see the gray spring steel clip that cg describes. It needs to be depressed to release the cable from the back of the speedometer case.
When re-installing the cable just pushing the cable in place snaps the clip automatically.
Regards,
Alan
Old Aug 28, 2017 | 06:47 PM
wer2xu's Avatar
wer2xu
Awesome, thanks everyone for the help!
been a while since i posted, they now have little thanks buttons....
Old Aug 28, 2017 | 09:33 PM
Duntov's Avatar
Duntov
Dumb question, does the cable pull out of the sheath at the gauge or trans?
Old Aug 28, 2017 | 10:51 PM
george2066's Avatar
george2066
Default cable replacement
can the whole cable be replaced without pulling the dash?
I think my cruise control transducer is shot or dirty, I do not use the cruise. Can I just get a cable from the trans to the speedometer without pulling the dash? Its a 77
thanks
To 1970 Speedometer and Cable questions
