Odd Tach behavior
Old Aug 31, 2017 | 01:44 PM
lsintampa's Avatar
lsintampa
Default Odd Tach behavior
1975 Coupe....
New tach board, zero set.... installed in car now.... it appears to be accurate (more or less), but when you turn off the motor, the needle stays where it was when the motor was turned off.
If you turn the ignition back on, the tach zeroes out as it should.
Not sure why it doesn't zero out when the motor is turned off.
Normal, or possessed?
Thanks,
Len
Old Aug 31, 2017 | 04:36 PM
'75's Avatar
'75
That's normal. The important thing is for it to go to zero when the key is on, then read correctly when running. Aside from that, nothing matters.
