74 454/High Engine Oil Pressure Question
Old Aug 31, 2017 | 02:51 PM
74VetteAZ's Avatar
74VetteAZ
Default 74 454/High Engine Oil Pressure Question
Hi All -
I'm trying to determine what the problem is with my 74/454. Reading oil pressure 0f 80 psi even after idle with engine warmed up. I'm trying to figure out the most likely cause. Also noticed a pretty good oil leak at the oil pan drain plug. I'm a newbie and trying to learn how so any advice on where to start would be much appreciated. Thank you!
Old Aug 31, 2017 | 03:14 PM
MelWff's Avatar
MelWff
you need to temporarily connect a hand held gauge to determine if you really have that high a pressure reading. Based on that test you either have a problem with the oil pump or the in car gauge.
what viscosity oil are you using?
Old Aug 31, 2017 | 03:29 PM
Neil B's Avatar
Neil B
Originally Posted by 74VetteAZ
Hi All -
Did the oil pressure increase all of a sudden with no changes to the engine? Or, has it always been that high?
Old Aug 31, 2017 | 03:30 PM
74VetteAZ's Avatar
74VetteAZ
Recently bought the car - not sure what oil is in it - oil filter is AC Delco - oil level is full. I thought maybe it could be the pressure sending unit?
Old Aug 31, 2017 | 03:34 PM
74VetteAZ's Avatar
74VetteAZ
Previously it was in the normal range - just went to start it up after sitting for a couple of weeks - pegged the gauge at 80 psi. After engine was at operating temp gauge still pegged at 80. When key is turned off gauge goes to zero
Old Aug 31, 2017 | 03:39 PM
Neil B's Avatar
Neil B
If it was fine a few weeks ago and then fully pegged the gauge when you recently started the car, it's likely the gauge sender.
Old Aug 31, 2017 | 03:49 PM
74VetteAZ's Avatar
74VetteAZ
Thank you very much - I'll start there - Part supplier shows one unit for that model year
(74) Do you know if the 454 uses the same pressure sending unit as the 350?
Old Aug 31, 2017 | 04:06 PM
69autoXr's Avatar
69autoXr
Did you drive the car to get the oil fully warmed up? My LT-1 pegs the oil pressure at 70 psi cold, and stays there (through the warmup) until I really start working the oil, then it drops to 35 psi at idle. This is with 20W-50 VR-1.
Old Aug 31, 2017 | 04:10 PM
74VetteAZ's Avatar
74VetteAZ
No did not drive the car - just ran until engine was in normal temp operating range then shut it down when I noticed the high pressure (pegged at 80). I will run it like you suggested and see if it drops before replacing the pressure sending unit. Thanks again!
Old Aug 31, 2017 | 04:16 PM
69autoXr's Avatar
69autoXr
Oil temperature generally lags behind the coolant temp, so the case may be that your oil hadn't fully warmed.
To 74 454/High Engine Oil Pressure Question
