Another headlight question
Old Sep 1, 2017 | 01:54 PM
sullyman56's Avatar
sullyman56
Default Another headlight question
I'm trying to get the headlights working on my 68 and came across what I believe to be a problem with the actuators. I've read all the troubleshooting threads and can't find an answer. All the vacuum lines are new and run according to the AIM. When I pull the headlight switch or use the override switch nothing happens. I'm pretty sure the tank is ok because after I shut it off and pull the headlight switch I can hear the relay working. I did find one seal torn on the front of the right actuator so I know that needs attention. The left one seems ok and holds vacuum when I tested it with the mightyvac. Since the relay functions correctly when the switch is pulled and nothing happens, could it be that I need to repair or replace the actuators? Any help with this will be greatly appreciated. Thanks in advance.
Old Sep 1, 2017 | 04:02 PM
SwampeastMike's Avatar
SwampeastMike
Since you have a hand vacuum pump the headlight vacuum actuators are very easy to check. You need to check both (front and rear) vacuum connections. A leak ONLY at the front connector means that the shaft seal needs to be replaced. The parts to do so are readily available. A leak at the rear means that the main diaphragm is faulty and the actuator needs to be replaced. While both sides should hold vacuum indefinitely a slow leak won't prevent them from operating. The front connection works to open the headlamp door; the rear one closes it.
Old Sep 1, 2017 | 05:19 PM
kanvasman's Avatar
kanvasman
Also, just double check to make sure all the lines are connected correctly. It can get confusing so use a diagram to make sure. Good luck.
Old Sep 1, 2017 | 05:48 PM
sullyman56's Avatar
sullyman56
I checked them with the vacuum pump and both have a slow leak at the rear ports. The left one leaks a little at the front port and the right will not hold vacuum at all. As for my connections, I followed the diagram that came with the new hose kit and I double checked with the AIM. Looks like I'll be buying new actuators. Thanks guys.
Old Sep 1, 2017 | 05:54 PM
croaker's Avatar
croaker
A tip buy from a source that actually checks they hold vacuum before shipping.
Old Sep 1, 2017 | 06:18 PM
sullyman56's Avatar
sullyman56
I'll do that. Thanks.
To Another headlight question
