Vibration under higher rev
Old Sep 4, 2017 | 10:22 AM
dyerk's Avatar
dyerk
Default Vibration under higher rev
i feel vibration in my 69 350 when I accelerate hard. I'm not sure where it is coming from. No noise from engine or trans. Anyone have ideas what to look for? Could a harmonic balancer cause this?
Old Sep 4, 2017 | 12:27 PM
TimAT's Avatar
TimAT
Did this just start? What was changed recently? Are the trans and engine mounts in good shape? Are all of the u-joint angles in limits? No binding anywhere in the driveline?
Old Sep 4, 2017 | 05:43 PM
Jamess411's Avatar
Jamess411
Also does it vibrate sitting in park? or if a 4 speed does it do it with the clutch in our out? Narrowing down when it does do it and doesnt do it is key in trying to figure out where to start.
Old Sep 4, 2017 | 06:09 PM
VERYSOON's Avatar
VERYSOON
Could be water pump bearings on the way out! Happened to me. Might check that.
VS
Old Sep 4, 2017 | 09:36 PM
dyerk's Avatar
dyerk
I just bought the car and haven't pushed it much. I will check the mount but what are u joint angle limits and how do I check? I did notice when the car is jack up in the rear that there is a thump as the wheels spin. I thought it was just due to extended angle on axle shafts
Old Sep 5, 2017 | 12:16 AM
TimAT's Avatar
TimAT
The thump when the rear wheels are hanging is the binding of the half shafts. Too much angle on those U joints.
Go to TREMEC's website- they have a smartphone app that measures and calculates driveline angles- handy thing to have.
If you look at the driveshaft with the car level and the driveline looks like it's not really centered in the tunnel it might be worth looking closer. Take a look at the front differential mount too- the rubber gets old and soft.
Old Aug 16, 2018 | 07:55 AM
dyerk's Avatar
dyerk
Sorry for the delay in replying to this post. Life got in the way. Coming back to the vibration. It happens with trans in neutral and clutch out (so not drivetrain). The vibration comes in around 3-3500rpm. I am not sure what updates have been done to the engine. Its a 350/350hp but the heads were swapped for a lower compression version from 72. I just bought a new harmonic balancer and belts and I will be installing these this weekend.
To Vibration under higher rev
