1980 Snubber Differential Mount bushing
Old Sep 5, 2017 | 03:03 PM
Burnt71's Avatar
Burnt71
Default 1980 Snubber Differential Mount bushing
Could someone post a diagram of a 80 -82 snubber mount differential mounting bolt diagram ? not sure how the rubber goes
Old Sep 5, 2017 | 03:17 PM
Street Rat's Avatar
Street Rat
Check out this link from Willcox Corvette...
http://repairs.willcoxcorvette.com/1...-instructions/
Old Sep 5, 2017 | 03:33 PM
Burnt71's Avatar
Burnt71
Guessing its the same for an 80 should be
Old Sep 6, 2017 | 02:10 PM
lakerider57's Avatar
lakerider57
Here is a little clearer diagram from another vendor:
Old Sep 6, 2017 | 02:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The picture on the link shown above can be enlarged by clicking on it, but there is a second picture on that link that deals with the 80-82 cars. I've posted it below. Please note: The hole in the bracket on the differential must be enlarged to run the current reproduction of this part. There is no other substitute, and never run poly in this location!
Willcox
Old Sep 6, 2017 | 11:53 PM
SciVette's Avatar
SciVette
Does the hole need to be enlarged to fit the bolt? The lower bushing looks flat with no protrusion to fit into the hole...
Old Sep 7, 2017 | 09:42 AM
0Willcox Corvette
Former Vendor
It has to be enlarged because the upper cushion has a sleeve made inside that must fit down into the bracket. The sleeve on the original 80-82 cushion was smaller, so the hole was smaller. The current reproduction upper cushion is made like the one used from 1963-1979.
Willcox
Old Sep 8, 2017 | 09:27 AM
Street Rat's Avatar
Street Rat
...and never run poly in this location!
Why is this?
Old Sep 8, 2017 | 09:31 AM
0Willcox Corvette
Former Vendor
Why is this?
https://www.corvetteforum.com/forums...destroyed.html
Old Sep 8, 2017 | 09:51 AM
Street Rat's Avatar
Street Rat
WOW!
I'm changing mine out asap.
Thanks Willcox.
Old Sep 8, 2017 | 05:53 PM
0Willcox Corvette
Former Vendor
WOW!
Thanks Willcox.
Your most welcome... The issue is that bushing is designed to have give... and when you increase the H/P it makes it even worse on the frame bracket.
Willcox
To 1980 Snubber Differential Mount bushing
