What are these things?
Old Oct 5, 2002 | 06:49 PM
ice pac's Avatar
ice pac
Default What are these things?
I was going over my engine yesterday and noticed two plug type things. Both appeared to be broken and/or missing pieces. I took a couple pics. Please help me out here. Thanks
--J.thib
Old Oct 5, 2002 | 07:04 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: What are these things? (ice pac)
temp dependent vacuum switch for EFE, the other is probably a temp sender.
Marck
Old Oct 5, 2002 | 08:14 PM
Chris69's Avatar
Chris69
In your picture, the missing fittings are temp controlled switches. The one on the right is for the EFE, as Twinnie said. It has twin vacuum ports, one going directly to the exhaust manifold EFE and the other has a T fitting to the carb and the air diverter valve of your air pump control assembly (all that stuff is missing from the your car). The other missing switch is the ECS (evaporative control system). It also has two ports, one going to the base of the carb (below your throttle position sensor) and the other goes to the fuel vapor canister. To the right of the missing fittings you'll see another fitting with a yellow & black wire. That's the temp sensor that's used by the computer.
[Modified by Chris81, 7:15 PM 10/5/2002]
Old Oct 5, 2002 | 08:25 PM
Paul L's Avatar
Paul L
Yours are long gone but one is the EFE TVS valve and the other is the EGR TVS valve. EFE is the early fuel evaporative system and EGR is the exhaust gas recirculation system. Both are thermal vacuum (TVS) actuated.
http://temp.corvetteforum.net/c3/pau...ssions_001.jpg
[Modified by paul79, 7:30 PM 10/5/2002]
Old Oct 5, 2002 | 08:29 PM
isosceles's Avatar
isosceles
Yeah,
I have the 2 switches hanging off my T-stat housing and kinda wished I didn't. I know with a carb that didn't have all that junk to depend on the car would probably run faster.
I hope to be the proud owner of a couple of those plugs one day or at least a new T-stat housing. :yesnod:
Old Oct 5, 2002 | 08:44 PM
Paul L's Avatar
Paul L
Default Re: What are these things? (isosceles)
I can get the GM numbers for those parts if you are interested.
Old Oct 5, 2002 | 10:33 PM
Chris69's Avatar
Chris69
Default Re: What are these things? (paul79)
paul79: Is there a difference on the 79's compared to the 81's? Mine is an ECS TVS for fuel vapor and just wondering how that co-exists with the EGR. Usually if the canister is good, but getting no vacuum, then you'd check the PCV. I'm probably missing something along the way... too many hoses!! :smash:
Old Oct 6, 2002 | 12:07 AM
ice pac's Avatar
ice pac
Yes I'm interested in those numbers but first I have to ask: What are the dangers of running without all the extra stuff? It was mentioned that they could perhaps hinder performance. If it's not a necessity I'll just leave things as they are and keep those holes plugged up.
Old Oct 6, 2002 | 01:22 AM
Stevo81's Avatar
Stevo81
Save those good-looking thermo vacuum switches and rebuild them !
Or ask the parts guy if there is a core charge.
Sorry, it's Saturday night.. :cheers:
There is no great RWHP loss here. EFE heat riser just keeps some hot exhaust for quicker warm-up. EGR just reburns exhaust gases...smog pump blows air into exhaust manifolds and cat to burn all exhaust...
Old Oct 6, 2002 | 08:27 AM
Paul L's Avatar
Paul L
Default Re: What are these things? (Chris81)
I do not have the vacuum schematic for a 1981 but I would think they would be different as you have a computer control system.
Old Oct 6, 2002 | 08:28 AM
Paul L's Avatar
Paul L
Default Re: What are these things? (Stevo81)
You are absolutely correct.
To What are these things?
