engine number decode
looking at a engine stamp on friends vette.
it's a 1972 - 350 auto cali car, looks all original.
V05"I"7CDJ
my understanding of the decoding, the 4th figure should be a "1" not the letter "I"
CDJ 1972 350 base, tur 400, NB2 K 200 - Vette/SS
is this a bad stamp from factory, or a bad re-stamp?
the vin number is cleanly stamped and straight.
the scuff lines are from us cleaning the gunk off.
V05"I"7CDJ
Received 1,469 Likes
Cruise-In II Veteran
Emerging Vendor
I would be more concerned if the vin stamp was similar to the engine code stamping. Can you see the broach marks? You can also check the casting number and date at the rear of the block. Date should be D or an early date E.
Received 2,878 Likes
Hi r au,
Here's an example of a gang holder used, and PERHAPS how the individual stamps were stored (in a tray?), at Flint.
Looking at these photos you can see why the spacing and alignment of the characters that compose the engine stamping were TYPICALLY even.
It appears there may have been a gang holder for each engine suffix since the suffix is marked on the holder. That would mean that typically only the date character would need to be changed each day.
Regards,
Alan
Regards,
Alan
V05"I"7CDJ
V05"I"7CDJ
