No oil through the oil filter
Old 09-19-2017, 02:09 AM
  #41
71VetteLover
71VetteLover's Avatar
Default Oil Pump Drive Shaft
When I say "oil pump drive shaft" I don't think he knows what I'm referring to. As I don't remember how to copy and paste links can someone help me out? Show him a ARP #135-7901 or Melling #IS-55E oil pump drive shaft?
Old 09-19-2017, 09:24 AM
  #42
BB72
BB72's Avatar
This is getting almost funny, my sarcasm is about to take over. THE MOTOR HAD OIL. It was dripping off the camshaft as I looked at it yesterday, the wind didn't blow it there. Those bearings don't look perfect but they're completely smooth and NOT burnt.
73racevette (09-19-2017)
Old 09-19-2017, 09:38 AM
  #43
427Hotrod
427Hotrod's Avatar
Received 1,877 Likes on 915 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
LOL.....
JIM
BB72 (09-19-2017)
Old 09-19-2017, 05:36 PM
  #44
71VetteLover
Default Oil Pump Drive Shaft Picture Please?
Then why was your oil filter bone dry and the inside of the block's oil filter boss also bone dry? Some kind of miracle perhaps? I'm still waiting for a picture of your OIL PUMP DRIVE SHAFT with the steel sleeve on it. The 1/2" X 6" shaft that connects the bottom of your HEI to the top of your oil pump. The rear of your #5 main bearing shows signs of being hot but the #4 main bearing definitely shows signs of burning from lack of oil pressure. You need to pull all of the connecting rod caps and see how much damage the rod bearings suffered.
I assume you put oil into the oil pan then hauled the engine to the dyno shop in the bed of a pickup? The trip to and from the dyno shop would be more than enough to slosh oil all over the insides of your crank case so just because you see oil dripping from the camshaft or crankshaft doesn't mean it had oil pressure during the 10 dyno pulls.
Old 09-19-2017, 05:51 PM
  #45
'75
'75's Avatar
As much as you're hoping the op's engine is fubar, it's not, it's just fine, no magic, just a simple misunderstanding. Re read the whole thread, you will understand!
Old 09-19-2017, 06:41 PM
  #46
lionelhutz
lionelhutz's Avatar
Is this a reading problem or ????
The pic of the bearing appears dark but is in fact clean and shiny. The dark spot on the bottom is excess oil sitting because of the way the cap is positioned. I know for sure I have a steel sleeve on the shaft. I worked 12hr nights all weekend and just got up, I'll have more updates later today.
Old 09-19-2017, 06:52 PM
  #47
71VetteLover
Default Home Made Oil System Priming Tool
Here's a picture of my oil system priming tool that I made out of an old cast iron Chevrolet V8 distributor 50 years ago. After I cut the top part off I cut and threaded the shaft 1/2" NF then screwed a 1/2" high nut onto it then pinned it with a roll pin. Then I ground the gear teeth completely off.
Once I button the engine up I drop the priming tool into place and use my 1/2" Milwaukee electric drill to spin it AND the oil pump. It only takes about 3 seconds to fill the one-quart filter and then UGH as it suddenly pressurizes the system.
I'll spin it for one minute with the #1 piston at TDC then rotate the crankshaft 90 degrees and spin it for another minute. After spinning it for one minute in each of the four 90 degree positions I know all of my hydraulic lifters got filled and it'll start clatter-free.
If you do very much engine building you need to make or buy a tool like this so you can pre-lube your system ahead of time.
Old 09-19-2017, 07:32 PM
  #48
cooper9811
cooper9811's Avatar
toobroke?
gungatim (09-25-2017)
Old 09-19-2017, 08:25 PM
  #49
'75
'75's Avatar
Originally Posted by cooper9811
toobroke?
My thought too!
Old 09-19-2017, 10:02 PM
  #50
BlackC3vette
BlackC3vette's Avatar
toobroke?
Your saying he changed his name???
Old 09-19-2017, 10:05 PM
  #51
427Hotrod
427Hotrod's Avatar
Gotta be......
JIM
Old 09-19-2017, 10:47 PM
  #52
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
Originally Posted by '75
My thought too!
Tell me it ain't so.
Old 09-19-2017, 11:20 PM
  #53
cooper9811
cooper9811's Avatar
He's done it before......
Old 09-19-2017, 11:37 PM
  #54
BB72
BB72's Avatar
Does anybody want a picture of my sleeved shaft? ......didn't think so.
Old 09-20-2017, 12:45 AM
  #55
centuryoldracer
centuryoldracer's Avatar
I hardly think I would get 10 pulls on the dyno going to 6000 rpm with no oil pressure and using hydraulic roller lifters without something grenading. As far as a balance issue, new balancer, new balanced bottom end a billet flywheel.
How much power did it make?
Old 09-20-2017, 04:51 AM
  #56
71VetteLover
Default Failure To Install The Oil Pump Drive Shaft?
We're still waiting for that picture of your oil pump drive shaft and pictures of the rest of your burned main and rod bearings. As the #1 and #2 rod bearings are the furthest distance from the oil pump that wasn't pumping any oil I suggest you look at those bearings first.
Old 09-20-2017, 05:40 AM
  #57
BB72
BB72's Avatar
It made 508 with 547ft/lbs. Not bad.
To No oil through the oil filter
Old 09-20-2017, 05:43 AM
  #58
BB72
BB72's Avatar
"we're"?.... No just you. What's an oil pump drive shaft?
Old 09-20-2017, 06:09 AM
  #59
71VetteLover
Put the #5 main bearing cap back on then blow air into the oil passage where the oil pump mounts. The air should come blowing out of the hole in the side of the oil filter boss.
Old 09-20-2017, 07:30 AM
  #60
BB72
BB72's Avatar
How long do I blow for? I'm getting light headed.
Quick Reply: No oil through the oil filter
