Driver side door mirror installation
So with that being said. I'm going to order a passenger side mirror,
will the template be the same
Or is the driver side mirror mounting different.
Since you already have the bracket inside the door you could drill it out and possibly us a Heli coil to replace the threads, or you could drill the holes out to 3/8" where the original bracket is and use the expander (well) nuts from the passenger side mirror mounting kit. The well nuts are not a standard size well nut too.. They are 3/8" but they have a very thin top to them vs the ones you'll find at your hardware store. If you decide to fish a new bracket into the door, I have a mid year bracket in stock that works great for this.
Willcox
