My T5WC transmission swop
Hi,
I'm working on my T5WC and as you can see, then I have a 10 spline shaft, so I need a new clutch kit. I was hoping that I had 26 spline, but no.
So now when I need a new clutch kit, then I also think I will buy a 21 lbs flywheel. (it is factory flywheel today)
Is the below what I need, will clutch work with my T5WC transmission?
The clutch I have today is 11"
Is the flywheel ok?
Can the flywheel bolts be re-used, or do they need to be changed every time you on bolt them?
https://www.summitracing.com/int/parts/ctf-df148552
http://www.ebay.com/itm/PRW-1628300-...53.m1438.l2649
Is the flywheel ok?
T Keith Alvey (08-17-2020)
Also one more thing, I measure 78mm (approx. 3") difference between my 4 speed and my 5 speed, so I have to shorten 78mm (3") of my driveshaft, is that correct?
Also will my speed cable fit into my T5WC?
