...I can't power brake...eek
Old Oct 6, 2002 | 06:47 PM
Aaron-74's Avatar
Aaron-74
Default ...I can't power brake...eek
Yesterday at my schools car show, I tried to power brake for a few friends..but, it didn't happen. The motor just kinda bogged down.
Why can't I power brake, I've got PLENTY of power :confused:
Old Oct 6, 2002 | 07:21 PM
SharkAttack's Avatar
SharkAttack
Default Re: ...I can't power brake...eek (Aaron-74)
When I had an auto, I recall having to press the brake softly and hit the gas hard and all at once (not gradually). The car will move forward slightly, so be sure nothing is around you in case the car launches or spins sideways.
[Modified by SharkAttack, 5:21 PM 10/6/2002]
Old Oct 6, 2002 | 07:27 PM
Cookwithvette's Avatar
Cookwithvette
When I tried my first power brake I stood on the brake and slowly brought the RPMs up. Then I began to release the brake enough for the rear tires to break but not enough to begin moving. You have an engine similar to mine, same transmission, and a much better rear gear. (at least for burnouts)You're right, you should be able to power brake. If I can with a 3.08 you certainly should.
Only thing I can think is is that your intake and cam don't build power under your torque converter's stall speed. I'm no expert so this is could be a load of :bs but those items could be the significant difference between our cars. Either that or you just have really freakin' good brakes. :lol:
[Modified by Cookwithvette, 11:29 PM 10/6/2002]
Old Oct 6, 2002 | 07:40 PM
Gordonm's Avatar
Gordonm
Default Re: ...I can't power brake...eek (Cookwithvette)
Get a line lock and you can power brake all day without ruining the rear brakes or rotors.
Old Oct 6, 2002 | 08:22 PM
Aaron-74's Avatar
Aaron-74
Default Re: ...I can't power brake...eek (Gordonm)
how much and how hard to instal??
Old Oct 6, 2002 | 09:55 PM
Gordonm's Avatar
Gordonm
Usually around 60 to 100 dollars depending on which one. Easy install. Plumb it into the front brakes line off the master clyinder. Run a couple of wires and good to go
Old Oct 6, 2002 | 10:35 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
i had the same problem.. you know what it was? the holley carburator that i had on it.. i changed that over to a demon, and the tires wont stop spinning :crazy:
Old Oct 6, 2002 | 11:03 PM
Aaron-74's Avatar
Aaron-74
Default Re: ...I can't power brake...eek (Corzvette69)
So, do I need a 12volt source for the line lock??
Old Oct 6, 2002 | 11:04 PM
Aaron-74's Avatar
Aaron-74
What's wrong with Holley's?
Old Oct 7, 2002 | 08:31 AM
Gordonm's Avatar
Gordonm
I have a Hooley and it runs good. The Demon is a better carb but the Holley should run fine properly tuned. Yes you need a 12 volt source. I put my button in the ashtray for the line lock and used the wire from the lighter.
Old Oct 7, 2002 | 01:13 PM
Woodstoc's Avatar
Woodstoc
Aaron, you may want to check your front brakes for proper operation. Sounds like all your stopping power is in the rear.
Old Oct 8, 2002 | 12:10 PM
Jman's Avatar
Jman
You just don't know how to do it. :p:
Old Oct 8, 2002 | 04:55 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: ...I can't power brake...eek (Jman)
i noticed with the 3.55s that i had to slam on the brake and gas at the same time :confused:
with the 4.11s i press the brake 1/2way and gun it. works pretty good :smash:
Old Oct 8, 2002 | 06:32 PM
Aaron-74's Avatar
Aaron-74
Default Re: ...I can't power brake...eek ('79ProwlerOrange)
I had a ricer friend come by today and he was talking smack..and I layed down a lot in the driveway. Me and my AutoShop teacher have been playing with the Holley....
Old Oct 8, 2002 | 07:35 PM
Jvette73's Avatar
Jvette73
One things for sure, you must have good rear brakes. I had air in my rear brakes and I could power brake real good. Then I bled them and it became very difficult to spin em. Line lock is the way to go.
Have you ever seen an onboard burnout system? Mount a windshield washer resevior with pump and run the hoses to a small hole directly above the rear tire. Rig it to a toggle or push button. Now you can wet your rear tires on demand. Works best if you can rig a nozzle that will spray an even band of your choice of fluid across the rear tires. Then, smoke em at will. :smash: :smash: :smash:
To ...I can't power brake...eek
