How to move parking brake bracket??
Old Sep 26, 2017 | 04:04 AM
BlackRocket's Avatar
BlackRocket
Default How to move parking brake bracket??
I would like to move the parking brake bracket from the side of the trailing arm to the top... (Have new 18x9.5 with 5.25 BS and the tires rub terribly on the brake cable!)
How does one detach the end of the brake cable to re-thread it from the bottom of the arm to the top? Does this require removal of the rear brake calipers and removing the brake disc/hub?
Thanks!
Old Sep 26, 2017 | 07:42 AM
Alan 71's Avatar
Alan 71
Hi,
Releasing the tension on the rear cable here:
Allows you to release the cable 'slug' here:
Regards,
Alan
Old Sep 26, 2017 | 07:56 AM
bazza77's Avatar
bazza77
medium size flat screw driver and some long nose pliers work well together to unhook the cable , watch the small white nylon wear guide doesn't fly off or break .
Old Sep 26, 2017 | 09:13 AM
Street Rat's Avatar
Street Rat
Delete please
Old Sep 26, 2017 | 09:19 AM
Street Rat's Avatar
Street Rat
You have to remove the caliper and disc rotor to get to the parking brake mechanism.
I cut the old bracket off of my trailing arms and made my own. Welded them on top to clear the bigger tire combination on my car,
To How to move parking brake bracket??
