outer window felts
Old Oct 1, 2017 | 07:05 AM
macka75's Avatar
macka75
Default outer window felts
Need new outer window seals. Who has best quality & fit
thanks
Old Oct 1, 2017 | 07:22 AM
Alan 71's Avatar
Alan 71
Hi m75,
People seem to like the door outer seals made by Corvette Central.
Be aware that the seals are slightly different for coupes or convertibles.
(It has to do with their length.)
Regards,
Alan
Old Oct 1, 2017 | 08:45 AM
macka75's Avatar
macka75
Originally Posted by Alan 71
Hi m75,
Regards,
Alan
Thanks I have a75 L82 coupe & living in Australia just want to get the best seals first time
Old Oct 1, 2017 | 09:07 AM
Alan 71's Avatar
Alan 71
Hi m,
There are 2 parts to the strip…...
One is the rubber part with just a small stainless steel bead that runs along it's length.
The other is a long piece of stainless steel trim that sits tight up against the edge of the fiberglass.
Be certain you oder the correct part.
Regards,
Alan
Old Oct 1, 2017 | 09:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There is only one company making the correct felts... One is supplied by PUI and they are generic, the other is supplied by a different supplier and they work every time.
We pull the generic felts from sales because they would drag the glass so hard that if you have power windows the wouldn't allow the window to run upwards..
Convertible felts https://willcoxcorvette.com/corvette...oduction-69-75
Coupe felts... 69-82 https://willcoxcorvette.com/corvette...oduction-69-82
Willcox
To outer window felts
