Ethanol question
Old Oct 4, 2017 | 02:14 PM
Kzrider1's Avatar
Kzrider1
Cruising
Default Ethanol question
I have a 1981 and was curious if the gas/ ethanol mix in today's fuel will have any negative impact on my engine/ fuel pump/ lines/ etc. I don't recall if there was such a fuel mix back then. Any thoughts?
Old Oct 4, 2017 | 02:28 PM
MelWff's Avatar
MelWff
what percentage, 10%? If so no issue, I've owned my car since 73 and have had no ethanol related issues.
Old Oct 4, 2017 | 02:50 PM
71VetteLover's Avatar
71VetteLover
Default Gasohol
Do you remember the gasohol disaster in the early 1970's? It turned the fuel hose in my chainsaw into a sticky goo resembling hot bubble gum.
Old Oct 4, 2017 | 03:37 PM
Kzrider1's Avatar
Kzrider1
Cruising
Oh Man! I totally forgot about Gasohol! Must be getting old and forgetful!
Old Oct 5, 2017 | 08:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ethanol ol will do the same to the old clear fuel lines. I had a 80s still saw that got ruined about 5 years ago. Also had it happen to a couple of old weed wackers. Newer products have different fuel line's. I think the newer rubber hoses are made to withstand the alcohol
Old Oct 5, 2017 | 09:13 AM
HeadsU.P.'s Avatar
HeadsU.P.
That nasty stuff will eat and destroy some carb parts, some fuel lines, some fuel pumps.
In other words, rubber parts. Go to Walley World and get a green bottle of Lucas Ethanol Safeguard. Only takes a couple ounces per tank full. Great additive for winter storage.
Old Oct 5, 2017 | 10:11 AM
See Three's Avatar
See Three
Ethanol is worse when you store your power equipment with it, not as bad for daily use. The last few tanks before storage should always be ethanol free.
To Ethanol question
