I know there were only a handfull of dealer modified LT1's in 1969. But now I have a driveway modified L46 350/350 with the LT1 cam, Alum intake and Holley 750 (they used a 780). I havent fired it up yet, but man it looks :cool:. I'll keep you posted on performance. BTW I shrink wrapped the #'s matching carb and intake for any NCRS events (not in my lifetime) but this was an easy low (relatvly) cost and easily reversible mod to the L46.
Because I want a car that I can do more mods on without ruining the value.
I have found out that I much prefer working on and modding a car than going to cruise nights an ddriving them. And in my opinion a 69 ragtop w/side exhaust and manual brakes and steering isnt much fun to drive anywhere more than 1 1/2 hours. I much prefer my new 02 Z28 for those kind of trips.
Soooo what I'm saying is until I sell her I'm going to keep putzing around with it.
I like your intake!!! The old "Torkers" and/or "Tarantula TM-1's" are awsome intakes... I have a ported and matched TM-1 on my 465 HP stroker engine...
Well I'm learning from my mistakes. Here's what I found.
#1 Looks great
#2 Slower than my Q-jet
#3 Car handles diffrent with less weight in front (not sure if I like it or not)
#4 Exhaust smell is bad at idle
#5 Not sure if secondaries are opening (GrandsportC3)
#6 Hard to set curb idle
Are you after the look of the LT-1 under the hood, or the actual feel of the LT-1 when driving?
For driving, you definitely want a dual plane intake.
Did you do a cam swap? What size exhaust? You could be dumping too much fuel without the ability to fully burn it or get the gases out.
There should be a noticeable difference in power (for the better) between an LT-1 and L46.
The exhaust smell is noticeable on mine.
The L46 is a more streetable driver.
[Modified by Robert N, 5:25 PM 10/7/2002]
If you look at the specs from the article about 4-5 posts above the LT-1 is actually slower than the L46 untill you hit about 90 mph. I like the look of LT1 under the hood.
I always wondered what the definition of "streetable" means? If it means drives good then thats what I want. That leaves everything else or not "streetable" what is that? Goes really fast but not reliably or often? I want something that looks cool, is reliable and goes faster than most other stock vettes.
If you keep the original parts and limit your mods to "bolt ons" I don't think there is a much better car to start from than what you've got. I have driven my car in a true LT1 configuration with the factory intake and cam. It was a great combination with good mileage, driveability, and very thrilling performance. If you are smelling fuel, or it is slower than your QJet, suffice it to say that it is not well tuned yet.
What about hood clearance. The L-46 is o.k. But for the hassle of the 11.0 compression and 91 octane, I would like it much quicker.The expense of the 110 race gas that I mix in definanltly helps, but I've been trying to figure out what to do. I've been considering doing the the LT1 clone as well. Any opinions?
I agree that the L46 is faster to 90 than the LT-1 in the article, but I have a tough time believing that from where I sit.
By "streetable". I mean easier to drive. The lope in the cam makes for a great idle and lot's of instant go, but driving in daily traffic and sitting at traffic lights is not so fun. Shifting is smoother between 3500 and 4000 rpms and that is difficult in traffic. The LT-1 (if I remember right) hit peak torque and power much later than the L46, so the power in the L46 is a more usable range.
I think Chuck is right about the tuning.
Other than that, the LT-1 intake was a dual plane and a single plane will make a drastic difference.
"Dual plane manifolds have shown to be more throttle and torque responsive at low and mid range rpm levels than most (but not all) single plane manifold designs." "[A single plane] has drawbacks, particularly as the number of cylinders increase. Intake pulses start to overlap, and that can mean that a cylinder will "rob" the cylinder following it in the firing order of charge- if they are located close to each other in the block."
The L46 and the LT1 are really only 10.5:1 cr. I never had any real problem with detonation if I used premium fuel. If I needed more octane, I have been very impressed with the "Supreme Lead 130". A quart per tank will raise 91 octane to 95-96 octane.
If you block the heat riser passage on the intake, you will significantly lower the octance requirement. An oil splash shield under the intake will also help. Ifpinging or detonation is a problem, I would suspect carbon buildup in the combustion chamber raising the effective compression ratio and glowing like little charcoal briquettes.
Get a Holley 4779 (750 double pumper) or even better - a 80528 (High Performance series 750 Double Pumper).. or any other 700 - 750 cfm mechanical secondaries carbs... A mech. secondaries carb should make a noticeable performance difference to the 80508 carb that you currently have (if it is a 80508).. This should solve your idle problem and add some power!!
I'm open to suggestions!
:cheers:
Olivier
[Modified by GrandSportC3, 9:11 PM 10/7/2002]
You are correct I do have the 80508 but I cant return it now. Any other way to improve the performance? I really miss the secondaries opening on the q-jet. :confused:
